Question about Lexmark X1150 All-In-One InkJet Printer
Can the copy setting be defaulted to black and white document?
Lexmark X1150
can the 'copy' setting be defaulted to black and white document, instead of the 'color photo' default? Most copies we make are black and white documents - not color photos.
  • 410 Answers
You can set it to B+W but it will revert to its default setting the next time you print.
Posted on Jun 30, 2009
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
Please help... when i scan more than 10 docs and then try to attach it to an email, it states that the file is too large ... please help me with my Lexmark X4270
You should setup the scan resolution to a lot less.
Scanned images can take a lot of space it scanned at high resolution and with many colors.
If it is a document, you can set it to scan black and white or gray and instead of the default resolution (300dpi) you should try scanning at 75dpi or 100dpi.
Those settings can reduce a scanned image to few ks instead of 10s of megs.
The average mail systems can't handle mail messages larger than 10Mb.
I would also suggest playing with the scanner to get the best results before trying to mail the scanned documents.
Nov 10, 2010 | Lexmark All-in-One Printer with PictBridge
I have a Lexmark X1150 printer that is printing purple only.
Try the "better" or "best" print options - They give more ink - might do the trick - (beware it also prints a lot more slowly....)
I have not had that type of problem as such as both my ink slots work, but I did have purple/bluish print instead of black once - It worked for me -
Hope that helps -
I have also found that despite cartridges being new somethimes they are not as full as they should....
May 03, 2009 | Lexmark X1150 All-In-One InkJet Printer
FAX with my Lexmark X1150
you can find a complete .pdf guide thats easy to understand by clicking the link below !
Lexmark X1100 series User Guide.pdf
Worry not , the X1100 series should match your x1150 model installation procedure!
Whatever O/S you use , you can get the Lexmark drivers to match from the Lexmark downloads section for X1100 series below ( also links to other models as well !)
Lexmark X1150 drivers & downloads / Choose your O/S
Jun 02, 2008 | Lexmark X1150 All-In-One InkJet Printer
Default status
SET YOUR PRINTER AS DEFAULT PRINTER
GO TO START - CONROL PANEL- PRINTER AND FAXES.
CHOOSE YOUR PRINTER RIGHT CLICK IT SET DEFAULT PRINTER .
THEN OK
U CAN GET PRINT
Apr 01, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1150 only prints first page
I have an x4550, running windows vista basic on an hp dv6000t notebook. i had the same problem. i contacted online lexmark tech and here's the solution that worked for me, thanks to help from lexmark (transcript of chat):
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. It should be set to the default to "LEMF." Change it to "Lexmark." Under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
Nov 19, 2007 | Lexmark X1150 All-In-One InkJet Printer
Black ink
Did you remove the tape from the cartridge when you installed it?
Has it ever printed black from this cartridge before?
You may need to wipe the cartridge with a moist paper towel at the place where the ink comes out. If there is dried up ink the nozzles could be clogged. Try running the Lexmark Solutions Center from the Windows Start menu (Start -> Programs -> Lexmark 1100 Series) and make sure the black ink level is good. You can also select "Clean Nozzles" in there and that may help.
Oct 15, 2007 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
327 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
