Question about Refrigerators
MY FRIDGE HAS WATER INSIDE - Refrigerators
The drain hole at the rear of the fridge is probably blocked. The water drains down onto a tray on top of the compressor and the evaporates with the heat from the compressor.
Try poking a piece of wire down, the channel can be quite long depending on what fridge you have.
Posted on Jun 30, 2009
Water accumulating inside the fridge
hi kostas.
Condensation runs down the back of the fridge and collects in the gully sitting at the back of the fridge where the water is then channelled through the drain hole into a container which sits on the compressor, it's then evaporated away.
How to Stop Water Collecting in Your Fridge ' eSpares
https://www.espares.co.uk/advice/.../how-to-stop-water-collecting-in-your-fridge Water accumulating inside the fridge Google Search
Nov 07, 2017 | Refrigerators
Water leaking out from inside and running out under the fridge. Do I need to clean out the outlet pipe and if so where would it be??
Check the drain tube that leads to the defrost pan under the fridge. The drain tube maybe plugged. Do you have water standing in the bottom of the fridge and if so that is probably the problem. However, something must be defrosting inside the fridge to create that much water. Be sure your fans are running inside the fridge.
Jan 08, 2016 | Refrigerators
Water runs down the inside back of the unit and freezes
Our fridge has a plastic hose running down the rear of the fridge and water was coming inside and running down inside the fridge walls and out the bottom of the door when we opened it. I called a repair man and he blew the plastic hose out and reinstalled it and had no trouble since. Our fridge has a water tray under neath the fridge that this hose is suppose to run into. The tray dries itself out so you don't have to empty it.
Mar 20, 2015 | Refrigerators
Water/ice build up in center column of fridge
clean the backside fins of the fridge..they get gummed up with dust and cannot cool the water effectively..clean inside and especially outside back and bottom..also..defrost it fully first..
Jan 08, 2014 | GE Refrigerators
I have water dripping down the back panel inside the fridge-it is constant. I wipe down the inside back wall, but hours later the water is back. The fridge appears to have a "channel" for this water
with out knowing name brand an model# i would say it sounds like there is a drain tube missing from the upper patr or freezwr area to the drain hole at the rear bottom . there is a drain pan under the refridge which catches this water then it evarperates. it also cab that the proper drain is pluged or blocked with algie which is comon try a little bleach to clean out the drain area
Nov 15, 2012 | Liebherr Refrigerators
Water is dripping inside the refrigerator ... Model f23elite
hello about the water dripping from inside your fridge.inside your fridge there should be a drainage hole were the water should drain out ,it should lead to a pipe that leads down the back of your fridge.try unblocking the hole and pipe this should help the water run away more freely
Apr 23, 2011 | Whirlpool Refrigerators
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
Water buildup inside of refrigerator
It may be the fact that your evaporater pan is not working. The freezer and fridge have drains inside them. The water inside and condensation go down tube that you see on backside of your fridge. This tube goes into a drainpan in the bottom and than evaporates.
You should also check to make sure your fridge and freezer are cold enough.
May 20, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
DEFROSTING/ WATER RUNNING ONTO FLOOR & INSIDE FRIDGE
Check to see if the run-off tube at the back is plugged.
I dont know how old the fridge is - but if it a couple years old check at the back or the fridge - there should be a tube running down the back of the fridge down into the bottom tray. This tube funnels water from the freezer (condensation, or water from the defrost) down onto the tray holding the compressor where it evaporates with help from the heat off the compressor. Sometimes this tube can get plugged up with some scum or mineral deposits, causing the built up water to drain from inside the fridge.
The tube shouldn't be too hard to remove and clean out with some hot water and pipe cleaners. Had the same issue on on a GE fridge last year.
Hope this helps!
Dec 30, 2008 | Whirlpool ET0WSRXML Top Freezer...
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
