Question about HP LaserJet 3050 All-In-One Printer
I have just installed a brand new HP 6500 All In One. Everything checks out, except that it won't send a fax. I get Error Code 344. When the top sheet is part way into the machine, it stops for nearly half a minute, then continues, but I get the error message. What to do? Bob
  • r9brown Jun 30, 2009
    I submitted this problem, and it was solved by a great FixYa technician (micromatical). He suggested that I go into the fax machine Setup menu, go to Advanced Setup, slow the Fax Rate, and disable the Error Correction Mode. I am faxing on Vonage, a VoIP system that makes the faxes very vulnerable to small burbles in the data flow. The ECM senses these and disconnects before the fax machine can establish a connection. After we changed these settings, the machine faxes just fine. I wish HP would put this approach in their troubleshooting guide!
    Scholar:
  • 119 Answers
You might want to make sure that you Fax service is properly setup on your printer and that all your hardware is properly functioning Visit http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01647469&lc=en&dlc=en&cc=us〈=en&product=3795314 for more information
Posted on Jun 30, 2009
My HP 8600 Premium no longer sends or accepts FAXes. It says it's connecting, but never does. And returns error 344. I know the other fax machines are working fine. Please advise.
Here's a document that explains some on the fax error codes: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=buu02549
The code 344 indicates noise or static on the line and usually the best way to get around that is to disable Error Correction Mode and/or lower the fax speed.
To disable the Error Correction Mode (ECM) touch the right arrow, then Setup, then Advanced Fax Setup, then down arrow and then Error Correction Mode and set it to Off.
To lower the fax speed, also go to Advanced Fax Setup and set it to Slow.
Nov 07, 2014 | HP Officejet Pro 8600 Premium e-All-in-One...
Hi my HP printer fax was working fine but now I am getting a 351 error message I rang the fax print test and everything seemed fine there
    1. On the product control panel, press the setup button (c01661990.gif ).
    2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
    3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OKbutton (c01335940.jpg ).
    4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
    5. If the ECM is off try turning it back On
    6. Check All these other settings
    7. Press the Setup button c01661990.gif Go to Advanced fax settings and check if the Fax speed is set to medium
          Oct 24, 2010 | HP Officejet 6500 Wireless All-in-One...
          Officejet 6500 error code 0x61011beb
          General error 0x610000F6 actually is a Carriage Jam issue
          Click Here for troubleshooting.
          Nov 11, 2009 | HP Officejet 6500 Wireless All-in-One...
          Fax error 344 - HP officejet 4255 all-in-one
          fax error is remote machine not responding to your fax.the other fax has stopped communicating.this is a comms error.
          Jun 29, 2009 | HP LaserJet 3050 All-In-One Printer
          Fax series 920, can receive but not send faxes, error code 344*
          Do you have or are you sending a fax to a party that has a DIGITAL PHONE SERVICE?
          Jun 04, 2009 | HP 920 Plain Paper Fax
          HP Officejet 4315v Error Code 344*
          1. issue may be with telephone line conditions,  try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to  hp at 1888 473 2963
          Jan 26, 2009 | HP Officejet 4315v All-In-One InkJet...
          Error code 344*
          Error code344 shows that The remote machine has failed to respond to a fax command from the product because the connection was interrupted.The remote user has pressed the Stop button while the remote machine was receiving.
          Under rare conditions, incompatibility between the two machines can cause the remote machine to simply abandon the call.
          check here for more information
          http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00062808#A5
          Fax
          344 Error can be caused by a few things. One of the following is occurring:
          The sending fax has failed to respond to a fax command from the receiving fax due to poor line quality or fax interruption.
          The sender has pressed cancel button while the reception was in progess.
          In rare conditions, incompatibility has been encountered by two faxes and causes the sending fax to abandon the fax call.
          Solutions:
          Fax session was using ECM. Check your fax settings under the fax set-up menu on the printer. Disable the ECM (Error Correction Mode).
          Fax at a different time to see if line quality improves.
          Try relocating the fax to a differnt phone plug.
          Replace the phone cord attached to the fax/printer.
          Aug 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
          HP LaserJet 3050 All-In-One Printer Logo
          258 people viewed this question
          Ben Johnson
          mukhtar21 shaikh
          mukhtar21 shaikh
