Question about Intex Plunger Valve & Straniner Basket set for 18' or larger pool set & Model# 51, 635, 633, 520R Filter Pump
Handle broke off and its stuck in off position.
If i take it apart can i open it ?
  • 93 Answers
YOU CAN THEY ARE REMOVABLE IF YOU CAN ACCESS YOU MAY BE ABLE TO MOVE BY PULLING UP ON CENTER PLUNGER WHERE HANDLE ATTATCHES AND PUTTING IN TO FILTER POSITION
Posted on Jun 30, 2009
Sunroof stuck open in vent position on 2007 pt cruiser
see if your tool kit with the spare wheel has a small crank handle there should be a removable plastic plug in the sun roof to close it manually. Apart from that, check the fuses.
Jan 16, 2016 | Cars & Trucks
Balay washing machine door wont open
We were staying in a holiday apartment and couldn't get the Balay washer/dryer door open on dryer cycle. Tried all the previous solutions and none worke. my husband turned the power off to apartment at fuse box and the door clicked open after a couple of minutes.
Feb 18, 2014 | Washing Machines
03 chevy silverado stuck tailgate
You can try taking the handle out and fishing the rods up to the opening. Other than that, its a tough job.
Jul 04, 2013 | 2003 Chevrolet Silverado 1500
My Tail gate is stuck in open position. WD40'd the ends, but the problem is in the tail gait. How do you get at it?
Lubrication is your only option, spray w40 using the little opening by the lid handle, also using that opening you can see if the bars attached to the handle are broke or loose, or don't move it all.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/flavio_517b938f50183b92
Dec 25, 2010 | 1993 Toyota Pickup
Both door locks do not work properly. I can only open the drivers side door from the inside. And the passengers side door will not open at all. This is on a 1999 Ford Explorer Sport.
Do any of the door handles inside or out feel sloppy (when you pull on them does it feel like there is nothing connected to them)?
If so that the levers on the latches are probably rusted up and sticking. Say for example the outside door handle lever that is attached to the door latch is stuck half way in the open position it will not allow the door lock mechanism to lock or unlock. The door will still latch and stay closed because the lever will not be stuck far enough to release the latch mechanism from hold on to the striker.
I have had pretty good luck removing the door latch (the part that actually holds the door closed) and soaking in penetrating lube and working all the levers until they move freely.
As far as the door that doesn't open I suspect it is stuck in the lock position and one of the handle mechanisms is in the partial up position. Again the symptom would be a sloppy door handle. That lever will need to be put back in its normal resting position before the door can be unlocked. This can be done with a slim jim. Once you have the door panel apart on the door that still opens you will be able to see the parts you need to move. You can then use that knowledge to move those parts on the other door that doesn't open.
If you don't have any experience with a lockout kit (i suspect most people do not) that that's the best way I can describe how you can do this yourself.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 29, 2010 | 1999 Ford Explorer
How do I open up my Microsoft Sidewinder so I can clean/repair it?
on the bottem of the mouse there should be 3 or four small screws, if they are not visable they will be hiding under the small rubber feet, undo all of the screws using a small philips screw driver, the 2 sections of the mouse should gently pull apart, if not then get hold of a thin flat object ie a knife and gently prise the 2 sections apart you may hear some clicks as it opens, dont worry as long as you are gentle it is just the plastic casps coming apart, once opened you should hopefully be able to repair the problem, and put the mouse back together the oposite way you took it apart. hope this helps.
Sep 20, 2010 | Microsoft Sidewinder Laser Gaming Mouse
Disk drawer will not open
can you hear the motor turning ? if so your belt needs changing, if you have a flashing green power light try changing the sata and power cables
Jan 25, 2010 | Microsoft Xbox 360 Console
My door latch will not lock in to place. It is below freezing and I dont know if the door is broke or the latch is just stuck
Likely it's just stuck. Spray it with wd 40 or other solvent and make sure the latch hook is open. If it's not, pull the door release handle (like you are opening the door) and gently pry the hook back to the open position.
Dec 10, 2009 | 2006 Jeep Wrangler
Hatch problem
Something has probably fallen apart inside. You'll have to take it apart from inside, and see what the problem is. Usually something pretty simple. Once you get it apart, you'll be able to open it by turning the little rod, or bar, with a pair of pliers, or stick a flat screwdrivewr in the hole and turn it.
Aug 30, 2009 | 2002 Mitsubishi Montero Sport
My zoom wont open , when i turn on my camera
Try Taking the Camera apart **VERY CAREFULLY** and manually try to open the zoom Yourself. Be Very Gentle and Delicate when the camera is apart. I had the same problem with a Canon. Took it apart and did that.. Works Fine Now..
Jun 30, 2009 | Fuji Rod Repair Kit
Intex Plunger Valve & Straniner Basket set for 18' or larger pool set & Model# 51, 635, 633, 520R Filter Pump Logo
285 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
