SOURCE: GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
From the Garmin web site:
Question:
What should I do if my Garmin nuvi / zumo displays the message “No Detailed Maps That Support Autorouting.”?
Answer:
Please follow these steps to troubleshoot the error message:
Checking the unit:
SOURCE: No detailed maps found to support routing
Have you tried updating the unit at Garmin's Website?
Let me know if you need help, I can get you the right web-link if needed.
Benjamin
SOURCE: garmin nuvi says, "no detailed maps found to support routing."
I am very sorry to hear that you are having problems with the unit. You
may need to switch the unit on and press and hold the centre of the
screen until the message ?No detailed maps? message disappears.
If your map detail is missing, then the map information may have been
disabled. To check to see if the mapping has been disabled, follow the
steps below:
From the Where to? and View Map page, touch the Spanner icon, settings
(Tools).
Touch Map.
Touch Map Info.
The unit should display the name of the map that is loaded to the unit.
The box in front of the map name should have a tick in it. If it does
not, touch the box to place a tick in it.
Then please test by searching for an address.
I was having the same problem. NO DETAILED MAPS FOUND SUPPORT ROUTING & SO ON. I called Garmin this morning & I thought I would be on the phone forever with the gentleman. But I was on for less then 10 minutes. The guy asked me to connect my Nuvi to the computer using a usb cable, then asked me to go into my computer & look for the device/drive that my Garmin is using. He then prompted me to open the file that says Garmin & asked me if there was this file that said gmapprom.unl. I told him no & then he sent me the file through an email. I had to open the file & get it into the Garmin file. Then he asked me to disconnect my Nuvi from my computer & it started right up & the problem was gone. If you do have the same problem I am willing to email you the file he sent me if you would like because there is no possble way to get the file from just searching on the computer. Let me know. [email protected] -Kathy
SOURCE: Garmin nuvi 205 shows no detailed maps found that support routing
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
this resolves the problem for you.
Regards
Richard.
