Question about Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
In my frigfidaire dryer there is a flashing going on behind the drum while it is running
    President:
  • 1,185 Answers
Switch it off and get a repair man in quick
You are shorting out the heater with ?
Posted on Jun 30, 2009
Modle number 2658866290 Where is the heat element on this dryer There is no heat
Usually behind the drum which means you might have to remove the drum to replace it.
Oct 30, 2017 | Dryers
Where is the heating element in dryer
Depends on the brand of dryer. GE dryers are usually directly behind the drum assembly which requires removing the drum to replace. Whirlpool dryers have the heater in a duct work running up the back of the dryer. Some other brands have the heater in a round pipe similar to the vent pipe in the bottom of the dryer. Would need dryer model to tell you exactly.
Mar 01, 2015 | Dryers
Dryer does not heat
Might be a limit or a the heater element.MY REPAIR PAGE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 15, 2012 | GE Dryers
THE DRYER MAKES A LOT OF NOISE AS IT TURNS
If yourdyer is making noise as it runs, then it is your drum bearing. It is located back behind the drum.
If you needto find parts or manuals for the dryer, go to Google website and type in youmodel number and then type in what you need manuals or parts.
May 11, 2011 | Maytag Dryers
New dryer looks like never been used (got in purchase of home), pulled lint trap to see for lint (clean) flashed light inside trap (clean), drum turns when on and clothes become warm/hot but not...
it is either the coil is going bad or the thermo safety is bad, there should be a wiring diagram(usually located in the back of the dryer behind the knobs, just unscrew the back plate) and you will see the safety limit. You can bypass and see if that is the problem, if it is make sure to get a new one as if you leave it bypassed and use it down the road it may cause a fire. Hope this helps tim
Sep 02, 2010 | Dryers
Replacing moisture sensor in Kitchenaid dryer. I have Kitchen Aid electric superba dryer model KEYS850GT0, ~15 years old. Runs great except the moisture sensor came out into the drum. The part appears to...
Go to www.repairclinic.com and enter KEYS850GT0. With luck you will be presented with a list of common replacement parts and may be able to view a generic KitchenAid dryer disassembly video.
Jul 17, 2017 | KitchenAid Dryers
I need to replace the belt in my GLER341AS2 model Frigidaire dryer. How do i open up the dryer to do so?
Unplug the dryer and using a 1/2 inch pait scraper locate the spring loded clips holding the top down to the front of the cabnet. They are located about one to two inches from the front corners of the dryer.
Lift the top and rest it on the wall behind the dryer.
Looking inside the dryer locate the screws holding the front panel to the cabnet and remove the screws.
Mark the wires to the door switch and remove.
Remove the front panel.
Go behind the dryer and remove the small rear panel near the bottom of the dryer.Observe how the belt is attached to the pulleys.Release the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go to the front of the dryer and grab the belt on the top of the dryer drum. Holding the belt lift the drum straight out holding the drum with the belt.
Check to see if all the rollers are in good shape and rotate freeley. Oil if needed.
Check to see if the teflon gliders located on the front panel that hold the drum are in good shape. Replace if needed.
Vaccum the inside of the dryer.
Put the new belt over the drum and line the drum up and install back into the dryer.
Put the front panel back on and reinstall the two screws.
Replace the door switch wires.
Make sure the grooves on the belt are flat to the dryer drum
Put the top down and go behind the dryer'
Locate the belt.
Pinch the belt and insert it under the tention pulley and slide it over the motor pulley. Make sure the belt is positioned straight and located where the old belt was positioned on the drum.
Jan 03, 2010 | Frigidaire GLER341A Electric Dryer
Loud noise from dryer
Good Afternoon,
If a toothbrush went into the dryer it would have to remain in the drum. There are no outlets large enough for a toothbrush to fit through. Can you tell where the noise is coming from? Also, check the drum good, the toothbrush could be hiding behind one of the ears in the drum and you probably can't see it. Try running your hand behind the ears inside the drum, it just might be there! I hope this will help you and thank you for using FixYa!
Mar 22, 2009 | Amana NDE2335AY Electric Dryer
Our 2-year old Frigidair dryer, Model # GLER341A was working fine-I removed the dry clothes, put in the next load, turned it on and it sounded like a load of chains was in it.. When I opened the door...
could be rear drum bearing. possible heat element broke and is rubbing on back of drum those light you say you saw was probably your heat element arcking on the metal in other words sparking
Jan 12, 2009 | Frigidaire GLER341A Electric Dryer
Danby dcd5505 dryer
remove the front panel(s) and the top panel. the belt will go around the drum to a drive wheel at the bottom. the belt turns the drum. You will have to route the belt around the drum and go either in front of or behind the drum to get the belt installed correctly.
Jul 03, 2008 | Dryers
Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer Logo
60 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
