Needle will not full size record - Audio Players & Recorders
  • 5 more comments
  • ghenderso895 Jun 30, 2009
    confusion reigns here I don't have a reciever problem. IT is a turntable problem the needle will not engage properly on a 33 1/3 record. To turn the unit on it must be closed. As soon as it starts turning it will automatically start to play only at the location of a 45 sped record the speed will play at 33 1/3 but only at the setting of a 45 sized record it decends each time at 17"
    IT IS A TECHNICS SL-5 TURNTABLE UNSURE HOW A RECIEVER WAS POSTED
    I have has no response to this issue I need to leave for a while and wanted to know if abyone has a clue about my technics sl-5 or if you only support those turntables listed
    It plays the record fine but manuevers only to the location of a 45 record. It changes speeds fine since it finds the 45 record correctly I have to assume it is not a mechanical problem
    i have not been able to find a manual for this turntable could this be a setting issue . it is a direct drive turntable so there is no spring involved
  • ghenderso895 Jul 01, 2009
    Well I had to take the uit apart and tape down the record detection switch. I will pay the price as the manual showed me thne switch which was missing on the unit
    the issue was resolved more by me than by the engineer online. He did find the manual I needed to resolve the problem
  • 11,896 Answers
I would recommend replacing the needle as they are resonably priced. Also check to make sure the record speed actually switches the speeds. Also make sure that the spring on the arm is not stretched out.
Posted on Jun 30, 2009
  • Nate Stansfield
    Nate Stansfield Jun 30, 2009
    Oh ok. I will do the best I can to locate a manual if there is one. It may be faulty drive or system error. But I will try to search for a manual
  • Nate Stansfield
    http://www.vinylengine.com/library/techn...
    Sergeant:
  • 326 Answers
May i know the exat model no please
  • 3,230 Answers
This information is less....
Please explain your problem in details.....
Thanks
Where can i get an adaptor for Harris Lanier Transcriber VoiceWriter 150 & 250. Im talking about playing a mini cassette on a large cassette machine. Thnx
I don't think that's possible, the minicassette won't fit between the spool spindles. You may be able to use a minicassette player, and route its output to the full-sized cassette recorder, though, or to a little transmitter that broadcasts to a matching receiver in the full-sized cassette player.
Aug 12, 2014 | Audio Players & Recorders
Needle stylus unit rubbing the record.
There's too much weight on the stylus or the needle is not inserted correctly.
May 15, 2017 | Office Equipment & Supplies
Record 930 Electronic, breaks needles in reverse on buttonholes
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Dec 14, 2012 | Bernina Sewing Machines
No power, misses at full thottle, carb is clean, will not pull it self in high gear,
Need To go up a size on you main jet and the upper slide needle needs to be moved up one notch that should make it run
Feb 03, 2011 | RTO 125cc Full Size Adult Quad ATV
I am unable to make the screen full size when the
you need to go into the settings on the box and turn off letterbox on the picture setting.
Mar 29, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
Please help someone... I want to record with a full screen but i cant seem to find the setting that changes the image size, right now it shows as 176/144, can this setting be changed ?or is this the only...
To know that it can be change, look for the option for your video recording and look for video size settings. You can do that when you open your video recorder.
Nov 10, 2009 | Samsung S7330 Cell Phone
What kind of phonograph needle do I need?
Is there any numbers or a makers name on the cartridge? If there is you can get the answer to your question by putting them into a search engine.
If there is no information on it, try looking the record deck up on the net.
Sep 17, 2009 | Electronics - Others
It is not a reciever it is a turntable and will not play a full size record it plays 33 1/3 but only sits down on a record as if it is a 45 record
There should be a size selector switch somewhere marked 7, 10(sometimes), 12. Your deck sound like it is set to the 7 setting.
Jun 30, 2009 | Audio Players & Recorders
Pioneer PL-670 record rejects continually
Are the record size tabs sticking up through the turntable platter cover? They sense the size of the record being played and adjust the run out distance for either 45 or 33 rpm records.
Jan 04, 2009 | Audio Players & Recorders
How long does a fully charged battery last?
Approximate number of recording images : AA size Alkaline batteries: 240 frames *1 AA size Ni-MH batteries (2500mAh): 420 frames *1 Test condition Conforming to CIPA(Camera & Imaging Products Association): *1: LCD monitor on, Full-size images: 2560x1920, Standard image quality, No instant playback, Flash used with 50% of the frames, No full-time AF, one image at every 30 sec., turning the power on/off at every ten images. Approximate period of playback images: Test condition Based on Konica Minolta's standard test method: AA size Alkaline batteries: 240 min. AA size Ni-MH batteries (2500mAh): 330 min. *Since the performance may vary depending on conditions, recording mode, and subjects, these are approximate values only.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
69 people viewed this question
 Grubhead
Grubhead
