The blade will be stuck on the shaft and both will be damaged and require replacement. With that knowledge you now understand that drilling a hole sideways through the blade cap isn't wrecking anything you are going to use again. You can then get something into the hole for leverage. Here in NZ blades are under $20 and motor shaft sleeve is about $5.
The shaft sleeve (the one on the motor shaft) is likely damaged. The correct solution is a new shaft sleeve and chopping blade. If you do not replace them both together the one you do not replace will damage the other one again.
It is extremely difficult to chop walnuts in a food processor, because they turn to powder within a few seconds. I have chopped them using both a Cuisinart food processor and a Moulinex La Machine. The difficulty arises because even after you have released the on or chop button, the blade continues to spin for a second or two. The Cuisinart DLC-8S is not particularly well-suited for chopping nuts, because the blade is not reversible - there are many Cuisinarts that do have reversible blades - a particularly good one is the Cuisinart DLC-2A, which has both a reversible blade and a Chop function (retails for about $29.99 to 39.99 nowadays).
The only way to have any success whatsoever with the DLC-8S is to press the pulse button and release immediately - only use a small amount of walntus - and then dump the bowl and add a few more at a time.
