Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
SOURCE: Vertical Green/Purple Lines on lower half of screen
I would contact RCA if the repair center dosent know how to troubleshoot this set. But I bet its an eeprom or ground issue. Contact RCA here at 580-634-0151 or At https://www.rca.com/secure/service/contactrca/1,,,00.html Good Luck
SOURCE: 3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
SOURCE: RCA Projection TV model #p61926
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
SOURCE: Image Distorted
This is a classic convergence problem. Please confirm that your model is 51H84 and whether or not you intend to repair this yourself. You will need to know how to solder. If you wish to attempt the repair, confirm the model and update this and I'll provide you with details and instructions.
Dan
