I have had a similar problem on two different STR-DE945s. In both cases pressing the power button sometimes worked, sometimes did not. Sometimes a soft touch would cause the receiver to turn on, sometimes it took a hard press. In one case pressing the power button would initially not take the receiver out of demo mode. In both of my receivers the fix was the same. On the Display board there was a broken solder joint on the 5 pin connector used to connect to the power button board. Just look very closely at the back of the Display board, near the '5' in the upper right corner. I fixed both my receivers by just re-soldering all 5 pins.
Unfortunately, electronics go obsolete very quickly, and the cost to repair a specific unit is so close to that of purchasing a new replacement that very few places stock parts or do repairs these days.
Unless electronics repair is a passion or hobby of yours, you will spend much time and effort trying to get parts, time trying to replace the defective parts (a waste of time and money if you aren't absolutely certain which parts are bad).
Since the complete board is no longer available, troubleshoot to the compnent level and replace the individual items on the defective board, or just get a new receiver.
SOURCE: Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
SOURCE: no sound from Sony STR-DH500 when playing dvds with HDMI
no sound via hdmi cables, you must use optical or coaxial
SOURCE: Sony STR-GX800ES receiver "protector" blinking - no sound
The most common problem found on FixYa for Audio Video
Receiver's is:
My receiver say's "Protect" or turns on then off.
What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To
determine your exact problem, the first step is to disconnect all
speaker wires "at your receiver" Next: Turn the receiver back on. If
your receiver still says "protect" or turns off, it needs to be
serviced. If your receiver stays on; reconnect your speakers one at a
time and power back up after
each speaker. You may find that after reconnecting all speaker wires it
works! Most commonly the small braids of wire from the + to the - have
touched and have caused the problem. In some instances, you noticed the
problem only when turning the volume up. either way, make sure the
exposed wires to your receiver are no longer than 1/2" long and are completely
under the screw down terminal or slide in. When you've found the wire
or speaker with the problem, your receiver will go back into "protect"
At this point, disconnect the wire from the speaker at the speaker that
may be causing the problem then test again.* Note* Make sure speaker
wires do Not touch each other as this Will cause a short! If you turn
the receiver back on and it stays on, you now know the problem is in
your speaker itself. To test your speaker, you will need a multimeter.
Set it to ohms resistance and touch the speaker terminals, if there is a
short internally the meter will read "1......" If it's an analog meter,
it will peg to the right. There's your problem. Now, within any speaker
there are quite a few possibilities as to what could be causing the
problem. Most common is a blown coil and the speaker needs to be
replaced. Some speakers have
internal crossovers (usually floor standing speakers) and may have a
shorted or burnt board (usually very visible brown burn marks on the
board) and can possibly be repaired if your handy with a soldering iron.
Now, if you disconnect the speaker wire at the speaker and it still
says "protect" Check your wire for the obvious cut or nail thru
the wire if possible. If your system has wiring that runs behind walls,
you may need to use your meter again. Disconnect the wire at both ends,
keep the ends separated, put your meter on ohms resistance and touch
probes to the + and - wires at one side. If the meter pegs to the right
or reads "1...." the wire is shorted and needs to be replaced or
repaired at the short. Hope this helps.
SOURCE: StR-DE945 stuck in auto protect mode
First of all my STR-DE845 started having the protector problem about 6 months ago and I bought this receiver back in 2001. This is what I found wrong with mine. After searching online I found a service manual for the receiver, this came in handy when diagnosing the problem. The first obvious thing was discoloration of the board around the IC 501, 601, and 701 Op-amps. When looking at the receiver from the front these are the three vertical NEC ICs to the right of the main amplifiers. Even with no load these amps get very warm. Sony failed to add any heat sink to these ICs so eventually they can de-solder themselves, specifically the 701 IC which is the one closest to the back of the unit. With mine I was able to slightly push the 701 more vertical, since it was leaning, and I believe it has helped it make a better contact. The protector circuit will kick in if it senses the Op-amps are shorted or not making contact. The best solution is to add some copper heat sink to these ICs, they already have screw slots for a heat sink. If they ever fail you will have to get new op-amps and re-solder them to the board. Hope this helps.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DE945-Receivers-manual/id/387dj982/t/2/
The far left optical connector on the back is an output.
