Question about Audiovox Bosch 718 World Cellular Phone
10yr Bosch Freezer: gsu2606gb of elderley neighbour playing up..
Elderley Bosch Freezer: gsu2606gb of an elderley neighbour is letting off an alarm sound, and alarm light is lit - temp indicates at -7.0 deg C (evid normally always at 18 deg C.) We have moved it out further from the wall, and moved away a coat that was hanging quite near to it. We've now given it best air circulation on this hot day.
The freezer alarm won't go off.
Possibly a problem with one of the components in the automatic defrost system in the freezer then.. this is the only reason why the alarm would keep sounding. Perhaps some of the moisture from the defrost has gotten in and damaged the electricals somehow. It might be worth it to store your freezer contents elsewhere and completely defrost the freezer and then heat the inside cabinet up with a hair dryer or something similar. This will dry out the cabinet and the electrical components. Once the freezer has warmed up let it stand for as long as possible with the doors open so that it reaches room temperature and then close the doors and switch back on. If this doesn't work you probably need a service engineer visit.
Oct 16, 2014 | Bosch Freezers
I have a free standing bosch fridge/freezer. There is water that is under the fridge and the alarm came on for the freezer section. I turned on Supercooling overnight and switched back to the original
It could be a defrosting issue. Make sure when you unplug your unit and let it defrost for 24-48 hours, make sure you put rags around the unit so if drain pan over flows, rags will absorb any excess water. If unit is partially defrosted, you will see water inside the freezer underneath.
Jan 02, 2018 | Bosch Refrigerators
Alarm light on
there is some problem of your engine you need to call freezer technician to check up the problem.
Apr 02, 2010 | Bosch 8.72 cu. ft. / 247 liter Chest...
Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 26, 2010 | Freezers
Drain was clogged and the dishwasher overflowed. It's a 10yr old Bosch dishwasher. Now water won't flow into the dishwasher but it runs through the cycle and dishes arent clean.
Probably the aquastop (if you have one). We have a similar problem after our owerflow. The dishwasher is starting and running through the programs but no water is coming.
Jul 31, 2009 | Bosch SHU9915UC Dishwasher
The alarm button is flashing
-18c is about 0 F. it shold be cold enough to freeze you know what.
you might want to turn the tempture up a little.
Apr 01, 2009 | Bosch 9.1 cu. ft. / 258 liter Upright...
Recently given a computer with an unknown administrator password
in Most of the computers ( if it has a backup recovery inbuilt). When computer starts keep on pressing F11 key on the top of your keyboard. In some computers this function is on F10. But make sure when you do system recovery you will loose all data if you would like to go for destructive recovery. If you want to backup ur files first dont go for destructive recovery but choose other recovery option.
If you dont have any backup system then you might have product key sticker somewhere on you computer. If its window Xp home then borrow XP home from someone and when it ask for product key enter that product key. THis way you can reinstall Operating system.
Hope it helps
please rate !!!
Sep 27, 2008 | Acer Aspireā„¢ T180 PC Desktop
Audiovox Bosch 718 World Cellular Phone Logo
41 people viewed this question
Top Audiovox Cell Phones Experts
svicari124
svicari124
Level 1 Expert
Laxman Bisht
Laxman Bisht
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
