Model WF T1210STG LG Fuzzy Logic 12.kg I opened the top back area and checked if there are burned wire. everything seemed to be ok and nothing smelled burnt.How do i know whats wrong with it
Did you check to see if there is a fuse blown on the machine ? Also you can go to utube and see if anyone has posted your model and where the problem maybe ? I also know that for the DYI person ;
"Time Life Books " has a series out on appliance repair , so call your local library to see if they have the book ? Hope this helps , Good Luck !!!!!!!!!!!! Grant
SOURCE: My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Call LG's support line, they have excellent customer service.
