Question about Porter Cable 10,000 Watt 20 Hp Portable Generator #H1000IS W...
10,000 watt porter cable generator will not generate
5 Suggested Answers
plkruger
  • 32 Answers
SOURCE: Porter-Cable generator won't power anything; engine runs, low rpm
You have a simple problem and it has nothing to do with the octane, honda's love better gas, thats all I use in all my equipment and even my 4000 psi pressure washer runs better and cooler with higher more efficient octane, Your problem is in the carb, clean and service it, make sure the air breather is clean (soap and water only if it is a foam unit and do not spray it with any oil) then check for water in the gas by draining the tank into a large clear glass container 1/2 gal at a time. and after all this is done and needs to be done anyway, change the spark plug run the unit and make sure the throttle up solenoid is adjusted properly or even working if this unit is equipped with one. good luck
Posted on Feb 05, 2009
CarlGehrke
  • 169 Answers
SOURCE: My porter cable generator 3000 wt will not stay running once star
If this generator has been stored for any length of time with fuel in the carb you probably have a plugged main jet in the carb. As joboo1 says there are a few other things that could cause this behavior, but most often I see dirty carbs, water in the fuel, and plugged/dirty air filters. Get a flashlight and look into the fuel tank thru the filler hole, if you see anything floating in there you've got water in the fuel. Look at the ari cleaner, oil and fuel on the element indicate a dirty carb. Of course check the oil level. Lastly, take the bowl off the bottom of the carb (shut off the fuel valve first), if you see debris in there the carb needs a good cleaning.
Regards,
Carl
Posted on Mar 01, 2009
pic498
  • 32 Answers
SOURCE: no electricity from generator
If you have a voltmeter, you can check the voltage coming out of the outlet. If you have some kind of residual voltage, such as 25 Volts AC or 10 volts ac, then you probably have a voltage regulator problem and your regulator will need to be replaced. If you read 0 volts then you you have an open between the output (outlet) and the windings of the stator.
Posted on Jun 13, 2009
  • 154 Answers
SOURCE: Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Posted on Jun 14, 2009
Produces no power
Check for a blown fuse or any loose wires
Feb 05, 2011 | Porter Cable 10,000 Watt 20 Hp Portable...
What type of oil do i take for a porter cable 5250 watt electric generator?
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
Oct 24, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
Low voltage, freqency appears erractic but engine speed is constant, auto idle surges
called hunting. Adjust the air fuel ratio crew until it stabilizes, The tur idle to specs.
Nov 19, 2009 | Porter Cable 10,000 Watt 20 Hp Portable...
Dec 22, 2008 | Porter Cable 10,000 Watt 20 Hp Portable...
Porter Cable 10,000 Watt 20 Hp Portable Generator #H1000IS W... Logo
127 people viewed this question
Top Porter Cable Electrical Supplies Experts
John Trevino
Spud Howell
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
