Question about AudioSource EQ-200 Home Equalizer
WHEN EQUALIZER IS ON LOW GRADE BUZZING/HISSING HEARD.
WHEN EQUALIZER IS ON,LOW GRADE BUZZING/HISSING HEARDTHROUGH SPEAKERS.WHAT COULD BE CAUSING THIS?THANKS TC
    Problem Solver:
  • 5 Answers
Have you isolated the problem to the equalizer only? By that, I mean remove it from the signal chain and bypass it completely. That's the first thing.Does the system make noise without it in? If dead quiet when removed then you go to step two.
If the noise returns when the EQ is reconnected, you should eliminate crappy or broken cables, connectors etc. Replace with a known good working set. Still there? Buzzing infers either a ground issue or some kind of power supply problem, only if the previous stuff is eliminated. Do this first, then ask again.
Posted on Nov 23, 2007
How can i hook-up a 901 series vi equalizer to a str-de897?
I own 901's(since new) with the active equalizer powered with a non-Sony surround sound receiver.
Basically, you use the MD/Tape in/out jacks to route the signal to the Bose active equalizer. Switch the Tape Monitor switch if no sound is heard.
Here are some references.
https://docs.sony.com/release/STRDE897.pdf http://products.bose.com/pdf/customer_service/owners/901_guide.pdf
Connect equalizer cables (4 total) to the MD/TAPE section of your receiver. OUT from the receiver to the equalizer IN and Out from the equalizer to IN on the receiver.
One issue with the equalizer running through the MD/Tape jacks is that it may affect any other speakers hooked up to your system.
Mar 15, 2016 | Audio Players & Recorders
How do I connect my behringer fbq1502 to my behringer professional mixer dx750.?
You have a sent and return http://www.behringer.com/assets/DJX750_M_EN.pdf
They explain it in the manual but the output from the mixer and between that the equalizer and the equalizer output to the speakers works great, not the tape..... they have a way lower S/n ratio and i've never heard of this solotion
Jun 19, 2014 | Behringer FBQ6200 Home Equalizer
Radio and CD player both emit a hissing or buzzing noise through the speakers like there is poor reception. However, all the local signals are found and play just fine, just the hiss!
The CD player cannot suffer from poor reception, so if you are having the same hissing / buzzing sound from the Bose system irrespective of the source you have selected , its is coming from the preamp / amplifier section.Also could be coming from the electronic source selector in the preamp section.You will need profession help
Mar 10, 2011 | Bose Audio Players & Recorders
PROBLEM CONNECTION SONY STR-DH800 TO BOSE 901 PASSIVE EQUALIZER
on my sony STR-DH800 only center speaker is heard the side speakers is very very low
Feb 18, 2010 | Bose 901 EQ1915 Home Equalizer
Can an equalizer cause hissing
The more ground the better,or check the RCA cables.or to see if the power wire is running any cables that power the inter.
Oct 26, 2009 | Alpine Type-R SPR-17LP Coaxial Car Speaker
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Motor noise coming out of speakers
you may have a short in one of your speaker wires, or your antania
Aug 07, 2009 | 1993 Buick Century
Speakers have hissing noise coming out of them
Hook a graphic equalizer between the piano and speakers, and turn down all sliders above 8 kHz. Since the highest note of a piano is 4186 Hz (4.186 kHz), you'll still hear all the notes but cut the hiss. If the hiss is coming from the speaker's power amplifier (in which case the equalizer won't help), turn down the speaker volume and turn up the piano volume. Live instruments generally need some doctoring to sound good through high-quality stereo equipment, as they only produce a limited range of frequencies whereas good speakers reproduce a lot more - including hiss.
Dec 25, 2008 | Onkyo GX-D90 Main / Stereo Speaker
Cant get rear speakers to Work AVR 745 7.2 Surround!!!
Another way to solve this rear speakers problems is to go to the equalizer and have the system recognizes the sound coming out of all speakers. The AVR 745 comes with a microphone on the stick, using that to run the manual equalizer. It is the manual equalizer will set the rear speakers.
Dec 29, 2007 | Harman Multimedia AVR 745 Receiver
AudioSource EQ-200 Home Equalizer Logo
267 people viewed this question
Top AudioSource Audio Players & Recorders Experts
 Grubhead
Grubhead
alberto55
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you an AudioSource Audio Player and Recorder Expert? Answer questions, earn points and help others
