Intermittent cooling 10dC above thermostat
The condensor exhaust motor only runs intermitently 1-2 minutes max whilst cooling takes place. I bought this as a clearence item. Am I right in thinking the gas is low?
What can be done
  • rudd_jason Jul 01, 2009
    I note that there is a large thud when the rear exhaust motor shuts off (like an internal flap slamming shut?) Warm air is produced out of the front cooling fan immediately after rear exhaust shut off. Exhaust is never warm (it was the first time). Temperature never gets below 25dC
    Does this help narrow the possibilities?
    Thanks
  • rudd_jason Jul 03, 2009
    Thanks Guys,
    I will try to return the item, if this proves problematic I will try and fix it my self.
  • 508 Answers
If its cooling during the on to two minute duration its not low on freon the fan on condensor has to operate in order for it to cool off freon to outside theres not a whole lot of info here to go by but here is some ideas-you may want to check outlet for a suuficient power supply and also that it is properly wired if not correct unit will not operate right(hardware sells a tester you plugh in with leds to tell if outlet is wired correct)also check breaker that it has sufficient amperage to suffice unit-if you bought on clearance it could be something that was brought back to store that was not functioning correctly-if unit is fairly new most are controlled with circuit boards may have problem in board-if not could be fan motor faulty for condensor-check switch and wiring for loose connections!!!Best of luck to You!You can also call manufacturer and register unit and then claim a warranty!!!!
Posted on Jul 02, 2009
  • 2,071 Answers
There are many causes why this unit works intermittently. This unit is prone to faulty motor running capacitor,for shorted or leaky.There three capacitor there you better check it one by one . Shorted or leaky capacitor can cause the unit to run intermitently. Also check refrigerant Freon gas or CF4 maybe out or slowly leak out. This unit also will goes on and off if there is a shortage gas involved . Also check the thermostat if its working. Also cold solder issue in contol panel circuit board and power supply board.
Good luck:
Regards:
VOTIT
Posted on Jul 01, 2009
  • LORETO LACARON
    LORETO LACARON Jul 01, 2009
    A cold solder joint is where a lead of a component is not soldered at a high enough temperature and results in a bad electrical connection which can respond to physical shock and thermal stress.Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected . When the aircon unit turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. A solder joint may also be broken or cracked because the was tug or hit. Look on the front and back of the board along the defective circuit to see any components that look like they are not soldered effectively or the solder connection is cracked or broken. A cold solder joint looks dull and/or bulging unlike the smooth and shiny normal solder joints. Its better you resolder all components parts joints of control panel circuit board and power supply board .
    Regards:
    VOTIT
2006 Chevy express van. Normally runs one mark below 1/2 mark. Lately ocassionally goes 1-2 marks above half way (usually when sitting idling). Have had coolant changed (Chevy dealer) and new radiator cap...
You've already eliminated #3 and #6, so keep checking...
Priority Action Part Type Cause
1 Inspect Radiator Cooling System Clogged.
2 Inspect Radiator Radiator Fins Obstructed.
3 Inspect Radiator Cap Worn or Damaged Radiator Cap.
4 Inspect Radiator Fan Motor Faulty Fan Motor.
5 Inspect Belt Incorrectly Routed, Adjusted (Tensioned), Missing or Worn Drive Belt(s).
6 Inspect Thermostat Faulty Thermostat.
7 Inspect Water Pump Worn, Cracked or Leaking Water Pump.
8 Inspect Radiator Fan Relay Intermittent Failure
Jul 16, 2011 | Chevrolet Express Cars & Trucks
I have a GE profile model # PFS22MBSAWW and about a year ago the digital display for the temperature reading would work intermittently. After some time I realized that when the condensor motor was on, the...
ou need to replace the main control board . in the back pt # wr55x10526 and you may also need the display pwb pt # wr55x10522 .. do the main board first and if diplay isn't working properly replace it also .. mm hope this helped .. feed back lps ..
Jul 10, 2011 | GE Profile Bottom-Freezer Refrigerator...
My frost free fridge freezer comes on for five minutes every half hour and is not cooling very well, what's the reason for this?
1 Check the thermostat settings i.e. temperature control. Hope it is not on the lower number. 2 If the thermostat setting is OK then there is every possibility that the cooling gas has leaked out. Call the technician and get it recharged. 3 Also check the compressor that it is working properly.
Jul 31, 2010 | Refrigerators
My frigidaire refrigerator does not cool? what should i buy for it
Good day.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condensor
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
Thank you for using FixYa
Jan 17, 2010 | Refrigerators
1998 chevy 3500hd, 6.5 turbo. has two new batteries and two new alternators but when hot there is an intermitant draw that dims the lights and puts a major drain on the electrical system when running. What...
Some educated guesses:-
Check the operation of the radiator cooling and air conditioner condensor fans.- There may be a seized fan motor causing the current draw.
With such a major current draw I would expect a fuse to blow or circuit breaker to operate - check all fuses installed in system are of correct rating,
Check for damaged (heat?) wiring adjacent to exhaust/turbo fittings.
Oct 29, 2009 | 1998 Chevrolet C/K 3500
My maytag skybox does not cool very well even when turned all the way to high.
1) your box may be low on freon,
2) fault thermostat may cause unit run non stop,
causing evaporator to ice up and blocking air
circulation,
3) Dirt condensor thus reducing operation efficiency.
Check the simplest problem first - make sure condensor
coil is clean. if not, use a vacuum cleaner to clean condensor.
For # 2 is more likely if the evaporator has a fan.
If it has, check to see if it runs; it is behind the back panel inside box.
While at that, see if evaporator coil iced up. If it is defrost using hot water and turn it on setting thermostat to normal temp. setting.
If it work fine and later develops same problem, replace thermostat.
If the above 2 solutions don't solve the problem, call a technician to check freon.
Oct 11, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
1970 Chevy 350 in C30 truck dies when warm
You need to find oput what you loose when the truck shuts off, all you need is Air, Fuel , and spark to run one of the three are droppuig out when it stalls and will not run. Chech the carb for gas it sounds like you have a weak fuel pump.
Sep 24, 2009 | 1983 Chevrolet K1500
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Dryer shuts off and won't restart until it cools off
more likely a bad motor ..excessive lint build up in dryer will reduce air flow through motor causing it to overheat problem is by the time the lint problem is found and corrected motor is already gone
Nov 20, 2008 | Crosley CDE6000 Electric Dryer
I have a hunter programable thermostat model number 44422 and the condenser outside will not kick on The fan is working inside but I have no cool air(air conditioning) I do not understand why the outside...
The outdoor unit has failed in some way. This is probably not the thermostats fault. You can check the breaker for the outdoor unit by turning it off and then back on. If this does not work, the problem is most commonly one of the following issues. All of which should be done by a professional because the danger of electrocution.
1) Bad Start/Run capacitor
2) Bad Compressor
3) Bad Exhaust fan motor
4) Combination of some or all of the above.
Jul 03, 2008 | Hunter Heating & Cooling
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
