Question about HP Pavilion dv4000 Notebook
Faulty memory slot
I've got a faulty memory slot. I can only use one of the two. Can I install a 2Gb RAM module into one slot. Would it work?
    President:
  • 317 Answers
With that make and model you can only put 1GB in each slot.
http://www.crucial.com/store/listparts.aspx?model=Pavilion%20dv4000%20Series
Posted on Nov 08, 2007
Repeatedly long beeps
If you upreage the RAM to 2Gb by inserting a 2nd 1Gb memory module then the 2nd RAM maybe faulty or incompatible.
If you insert a 2gb memory module to replace the 1Gb memory module then it maybe faulty or incompatible.
Try using the same make and RAM speed as the original RAM module.
Dec 29, 2012 | Biostar G31-M7 TE Motherboard
New memory, the board just beeps
First of all that board supports DDR400 (PC3200) so why did you get PC2100 chips?
Anyway, do a bare minimum test (only MB, CPU, RAM & PSU connected, nothing else). Remove all the RAM and test each one individually. Properly insert one into the first RAM slot and test by booting until the POST RAM test is finished. Shutdown and repeat the test with the same RAM module in slot 2 and keep repeating this for every slot. If successful in every slot, mark that module as working then try the other RAM modules using the same procedure.
  • As soon as you find one that doesn't fully pass the POST test, mark it as faulty.
  • If some pass in one slot but not another, then mark it as faulty.
  • If they all fail to pass on a specific slot, mark that slot as faulty and don't use it (you can use electrical tape to cover the slot for future reference).
Once you've finished the bare minimum test, try 2 RAM modules this time (use only the modules that you found to be working from the above tests). Mix and match the RAM modules & then try 3 together and even 4 (if you found all of them to be working fine).
Finally once you're satisfied you've found the modules that work properly, boot with memtest and test the RAM for any problems. If they all seem to work fine individually, boot them individually and test with memtest to determine which ones are actually faulty.
Jul 13, 2012 | HP Compaq Presario SR1610NX (ED865AA) PC...
Installed 4GB upgrade in optiplex 330 still only 2GB memmory
Your BIOS should automatically detect your new RAM when your computer starts, try starting your computer after removing your old RAM module, if it starts, you need to update your BIOS to use 4GB. If it doesn't start, you either have a faulty RAM module or a faulty connector on your motherboard. Insert the new RAM module into the slot the old RAM module was in, if your computer still refuses to start, you have a faulty RAM module which should be returned, if it does start, it's the connector on the motherboard, and only replacing the entire board will fix the problem. However, it's worth noting that your motherboard will only support RAM modules of 2GB or less, the above was written with the assumption you're adding an additional 2GB module to your Dell computer.
Dec 24, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
I m trying to upgrade my HP compaq nc6320 RAM MEMORY from 1GB to 4GB, Do i need BIOS upgrade if yes from were i can find the drivers and how can i do it? thanx i am gone wait for respond......
As far as I know, the machine supports 4GB of ram, so you purchase the ram modules from a pc parts dealer and install them inside the machine, removing the existing ram, there are 2 slots, so you need 2, 2GB cards.
You do not require any drivers or bios update.
Windows will need to be upgraded to 64Bit version if you wish to use the full capacity. as normal windows is limited to 3-3.75GB
Further questions? let me know.
Sep 01, 2011 | HP Compaq nc6320 Notebook
My 2nd memory slot for ram is not working can this be repaired?
Beforeyouassume the 2nd RAM slot is faulty check the following.
When instaling RAM in the 2nd memory slot this RAM may not be compatible with the RAM in the 1st memory slot or the RAM may be faulty.
Try and use the same make, speed and size RAM modules.
If the RAM slot is faulty, chances are it cannot be repaired.
Aug 27, 2011 | Computers & Internet
I have a toshiba satellite A135-S4467 laptop, using two memory slots, totaling 1G. I've bought a Kingston ValueRAM - 2GB PC2-6400 DDR2 Laptop Memory Module. What is the best way to install my new 2G...
Hi, Yes, it would be best to take the old RAM out. I am assuming that this is 1 stick totalling 2GB. Optimally it would be good to have 2 x 1GB modules totaling 2GB, so they could work together. Otherwise, yes, just remove the the old ram and install the new module. If you are running a 32bit operating system, 3GB is all the system can use anyway. Hope this helps!
Jul 13, 2011 | Computers & Internet
My DG41TX works perfectly with dual core processors, but with core 2 duo not, do 3 beeps and dont show any video, what i must do?? my core 2 duo is E8400 my dual core is E2180 Bios Version:...
The POST beep code - 3 short beeps mean RAM failure.
Try reseating the RAM modules.
If this does not solve your problem then remove all the RAM modules and insert one RAM module at a time into memory slot 0 (1st memory slot) to determine which is the faulty RAM module.
Jul 07, 2011 | Intel DG41TX Motherboard
Dell dimension 4700- added 2gb module in memory slot one, color coded white, and added 2gb module slot 3, also color coded white. only 2 gb recognized by computer, the second module is not recognized. ...
This motherboard uses inter-leaved RAM and RAM needs to be installed in pairs.
Check the BIOS RAM settings.
Try and use the same make of RAM.
One of the RAM modules may be faulty.
Try inserting the RAM module that was in slot 3 to slot 1
Feb 19, 2011 | Dell Dimension™ B110 PC Desktop
RK549AA-ABA SR2170NX problem: i think my second slot for ram is no good. i'm supposed to be able to install 2 gb max . I bought 1gb ram to install in slot # 2 but it doesn't work. can i install...
Is the 1Gb RAM you purchase the same make and speed as the original? If not, they may not be compatible with each other or the new RAM module may be faulty.
Try removing the RAM from slot 1 and insert the new 1Gb RAM module in slot and boot up your laptop to test the new 1GB RAM module.
Installing a single 2Gb RAM module should work.
Dec 29, 2010 | Computers & Internet
HP Pavilion dv4000 Notebook Logo
148 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
