Question about Shure WH20 Headset Microphone Microphone
I have 2 wh20 shure mics that do not work
I have 2 shure mics that due to my sweat due to my teaching spin classes has caused these to not project my voice anymore, i used the same mic at my gym with my transmitter so I know it's my mics,
can these be repaired easily? and where can they be repaired in the dallas area.
Thanks
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
Send them to Shure for repairs. www.shure.com/service
Posted on Jul 15, 2010
I have a client who wants to put hardwired headsets into house sound breakout rooms. Can I use a Shure PG30TQG or a WH20TQG and convert it to hardwire with a MX1BP
Bring a dynamic mic, the WH20 just needs a new connector put on it. The PG30 would need the MX1BP or the RK100PK with a phantom power supply.
Sep 06, 2013 | Shure PG30-TQG Consumer Microphone
New Shure PG4. RF and audio fm mic OK to PG4 but can't get mic to work with Peavy 680E. Tried different inputs, cables. Other wireless unts works OK. Wonder if pinout is wrong. Using balanced in/out.
Sounds like a complicated issue. Many things could cause this symptom. Try calling Shure at 800-516-525 to see if they can help troubleshoot.
May 04, 2011 | Shure PG42 Microphone
We are using a Shure PG58 wireless mic. It worked very well for about 1 year and then it would work on/off. Even when we put new batteries in the mic it still just goes dead. Any suggestions?
Unfortunately, there are many, many things that can cause a unit to be non-functional. Try calling Shure to get it repaired, or call Delta Audio at 773-764-3634. Delta Audio also repairs older Shure equipment.
Jan 17, 2011 | Shure UT2 / 58 / PG58 Professional...
All power on, signal is reading on receiver. No sound coming out . Tried changing xlr cable. tried wired mic to see if its a cable problem. wired mic works. changed batteries no results
Unfortunately, there are many things that can cause this symptom. I suggest calling Shure Applications at 800-516-2525. They can help you troubleshoot your wireless.
Jan 14, 2011 | Shure SLX2/Beta87A Professional Microphone
I have a well used shure pg58 that wont turn on.
It's hard to tell what might be causing the mic to not power on. It would be best to send the mic to Shure for repairs. Contact Shure Service.
Apr 21, 2010 | Shure (LX287CC) Professional Microphone
Shure ULXP4 with handheld wireless mic tx indicator and hum
There are many things that could be causing these types of symptoms. Try calling Shure and asking for their Applications Engineering Department. They can help you troubleshoot your wireless.
Jan 22, 2010 | Shure ULXP4 Receiver
Shure WB98H
OK....does it scratch when the cable going into the mic moves, or when the cable going into the connector @ the beltpack? Either way, Shure has an exceptional service policy on all of their mics. They have very reasonable prices for bringing their mics back to factory spec. If you are a touring musician who needs it ASAP, they are good at expediting the process. I always advise clients who use wireless mics to put a fresh Duracell battery in before EVERY performance. I am not an endorsee of that brand, but from experience, I am an endorser of it. A weak battery will cause static/scratches/drop outs. Call 800.516.2525(service line) or go to service@shure.com. Unless you are REALLY good at precise soldering, this is not a DIY project.Good Luck
Oct 01, 2008 | Shure WB98H / C Professional Microphone
Shure SLX Wireless Microphone Packs
I'm glad you brought this up. I had the same issues with sweat with someone wearing this. The best thing to do about this is to air dry them. If you use any chemicals such as a sanitizer, only use it on the plastic piece the goes around the head. Make sure it is safe to use on plastic surfaces. The electronics are protected very well on the headsets to prevent them from getting moisture inside but inspect the units for any cracks. If the mic was dropping it would be caused by a short in the wire between the headset and the pack.
The units are designed to be stacked on top of each other, but if the range from the mixer unit to the stage is too far, there are extension antennas you can get to amplify the signal on the receiver end. Having the transmitter and receiver too far apart or obstructed due to walls, can cause the signal to drop.
What is the range between the mixer board and the stage? Is the mixer board located in on another floor with a wall in front of it?
reinforcing the microphones may make it tough for the next person to use them if they need to be adjusted. It could void the warranty if it is still under coverage.
Aug 24, 2008 | Shure SLX UHF Headset Wireless System...
Headset stops working
There are many, many things that could cause this symptom. You might need to send it to Shure for repairs. I'd suggest calling Shure Support at 847-600-8440 for assistance in troubleshooting.
Feb 22, 2008 | Shure PGX14/20 Professional Headset
Shure WH20 Headset Microphone Microphone Logo
285 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
