Question about Sport & Outdoor - Others
I do not think the magnet and mounting bracket on my Bell f20 Bike Computer are aligned properly, but can't find an image of what it is supposed to look like. Thermometer and clock work fine. No other stats taken. Can any one help?
    Problem Solver:
  • 6 Answers
Many mounting brackets have an alignment mark on the sensor that should be aligned with the center of the magnet. The distance between the sensor and magnet is also critical, usually needs to be 1-2 mm.
Posted on Jun 30, 2009
How to install the bell 800 recline 800 bike seat
That tube is the seat post. Without the proper clamp, you're screwed. Contact local bike shop for assistance
Aug 23, 2014 | Cycling
My hero honda cbz bike vibrates after increasing speed more than 60
Hi, Anonymous and the usual suspects are:
1. Wheels and or tires unbalanced, worn or damaged.
2. Engine/ transmission/vehicle not aligned properly.
3. Primary chain is badly worn or links are tight as a result of insufficient lubrication or misalignment.
4. Engine to transmission mounting bolts loose.
5. Upper engine mounting bracket loose.
6. Ignition timing incorrect/poorly tuned engine
7. Internal engine problem, flywheels shifted.
8. Broken frame.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
http://www.honda.com.pe/extranet/images/Archivos/Documento/Passion%20Plus.pdf
Nov 26, 2012 | Bajaj Pulsar 150 Motorcycles
I have a Bell F12 Bike computer. After hitting a bump, the magnet fell out of the plastic housing mounted to the spole. Where can I get a replacemnt magnet? The unit is relatively new so I prefer not to...
Any magnet will work... modify a refrigerator magnet and superglue it to the plastic housing. Some of them are soft enough to cut or sand to a specific shape. As long as you get the magnet close enough to the sensor even a weaker magnet should work just fine, but starting with a good strong magnet will make everything easier. Good luck!
Aug 14, 2011 | Bell Sports Bell F12 Bike Computer
When i am riding the bike it is not telling me the speed
Some possible solutions:
computer unit is not "clicked in" to the handlebar mount. Remove it and re-seat it all the way in.
the spoke magnet and the pickup sensor on the fork are not close enough for a reading. Make sure that they are properly aligned vertically, and only about 1-3mm apart.
the battery in the unit is old and should be replaced. If you have a tester, you can check this. It will mean resetting the unit one way or the other. Replacement batteries are sometimes available at the "dollar" store.
sometimes the wire leads (if the Vetta RT55 is not wireless) into the handlebar mount become loose. They can be pushed back in, but this generally means the mount has to be replaced, if possible and economical, or the unit scrapped.
I hope this helps; good luck!
Nov 21, 2010 | Vetta RT55 10 Function Bike Computer
The sensor does not pick up the signal from the magnet.
TRY AND GET THE SENSOR AND MAGNET CLOSER TOGETHER.AND MAKE SURE THE MAGNET PASSES THE CENTRE OF THE SENSOR.MINE PASSES WITH A 3 TO 4MM GAP BETWEEN THEM
Sep 08, 2010 | Bell Sports Bell F12 Bike Computer
Lost my manual and am trying to reset my bell f20.
Somewhere in the configuration program is the option; if you can't find it it in the instructions, that's probably because it doesn't have this option, in which case, you should try and trade the bike comp. off for an American-built one. (guaranteed to have MPH)
Aug 05, 2009 | Cycling
Bell f20 computer - no code for 25'' wheels?
when i first got mine it prompted me to enter the circumference of my tire in millimeters (mine was 2074mm). you can get back to this by holding the bottom button in the center (this button is really two buttons one on the left side the other on the right side; holding the center pushes both these buttons). when it rests you'll see the 4 digit numbers. i think u use the right button to change the number and the left to move to the next. remember the number represents your tires circumference in millimeters. for a quick approx use this calculation (Tire Diameter)X(3.14)X(25.4). So for me it was (26in)X(3.14)X(25.4) = 2074mm
Apr 12, 2009 | Bell Sport & Outdoor - Others
Bell f20
here are the wheel value for a Bell F20
Road Bike
20" 1596
22 1759
24 1916
26 2073
27 2124
Montain Bike
24" 1888
26 2045
27 2155
28 2237
I hope this helps set your F20 computer.
Sep 11, 2008 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
194 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
