Electrical Problem? My Goodman is not turning on, nor is the fan, I have troubleshot, but is there a way to reset?
    Sergeant:
  • 340 Answers
Circuit breaker tripped? i'd call for service . Tom
Posted on Jun 30, 2009
Goodman a c fan spinning backwards, how do I fix it?
There is a plastic electrical connector going to the outdoor fan motor with two wires attached.
Take note of the wire colors entering and leaving this electrical connector.
Unplug connector and rotate connector 180 degrees so when you plug it back it, the wire colors have been reversed on the leaving side of the electrical connector.
This will reverse the fan rotation.
Sep 28, 2016 | Goodman Heating & Cooling
Goodman GDS80703AXBB
It could be the flame sensor. It is located in the burner box Opposite from the ignitor. It is a metal rod with a porcelain base. The flame sensor "senses" a small electric current through the flame. If the sensor is dirty it can impede the electrical current and cause the control board to lock out. Remove the sensor and clean the rod with some steel wool or sandpaper. Reinstall and see if this solves the problem. Hope this helps.
Jan 19, 2014 | Goodman Heating & Cooling
Blower motor makes noise, but does not work goodman
its either a bad motor or bad capacitor if you try to spin the wheel by hand and it starts then its the capacitor
Dec 26, 2012 | Goodman Heating & Cooling
Hello... I have a Goodman CKL49 a/c unit on the exterior of my house. I have checked everything I can think of and isolated the issue to the fan motor not turning on. The unit will recieve the signal from...
Hello, try using a small object to push the fan with power applied to it, if this gets the fan going tnen the capacitor must be replaced. If the fan does not start up then the motor is shot and must be replaced.
Sep 02, 2011 | Goodman CKL49AR49 Air Conditioner
Condeser unit fan not turning.
Hello, most likely youmhave a bad capaitor or bad fan motor. If you push the fan and it gets going than the capacitor is bad,if not bad fan motor.
Jun 08, 2011 | Goodman CKL36AR36 Air Conditioner
I am looking for the name of what the metal cover is called on the goodman air conditioners
1) Fan Shroud
2) Electrical Service Panel/ Electrical Cover
3) Electrical Disconnect-which is usually purchased
and mounted to the house.
Jun 25, 2010 | Goodman CKL24AR24 Air Conditioner
Inside fan running outside not
There is an electrical box on the wall near the outdoor unit. open it and be sure that the circuit breaker is in the on position. Same in your electrical panel, be sure that the circuit breaker is turned on.
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
My goodman compressor fan isn't turning since breakers thrown in box. mfg CR34K6PFV220 could this be a silonoid or perhaps something blown in the unit I can fix??I can't seem to get the case off. I do have...
turn tsat off and try to turn fan blade with a screwdriver through the shroud on top if does not turn freely motor locked up. there is a capacitor in the electrical section usually round with three sets of wire terminals on top if top is is dome shaped part is bad may have to look close to notice dome shape you reset breaker by turning breaker off then back on if it trips again very bad news 80% of the time
Jun 04, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
