Question about Epson Aculaser C1100 Printer
Epson Aculaser C9100 Colour Laser printer
Machine displays "Toner waste unit near full", we have just changed the toner waste unit but the message still displays
  • Epson Master
  • 691 Answers
If you changed the bottle and rebooted the printer with no change, it could be that the sensor for the bottle may be faulty. Try cleaning it:
1. Remove the CASSETTE ASSY.
3. Remove the two screws (silver, flanged, 8mm) that secure the COVER over the sensors. Remove the Snap from the main unit Frame, and remove the sensor COVER.
4. Use a paper towel or cloth to clean the sensor area of any dust or toner
Posted on Feb 20, 2008
Epson C2600N waste toner collector full warning, after replacing the collector
You have emptied the waste toner bottle, now you have to tell the printer that you have done so. The waste toner collection system has a "latch" (electrical signal) that is tripped when the bottle is full. it may be a pressure sensitive switch under the bottle or a photo-sensor that senses the toner level when full. I don't know the sequence of events to "switch" that latch. Usually on the larger machines it is a series of keystrokes on the printer's keypad, starting with turning the machine off and holding down a series of keys while turning the machine on (known as the "maintenance mode". Once you are in the maintenance mode, you can "trip" that "latch" to let the copier know that the toner collection bottle has been emptied.
Sep 22, 2012 | Epson AcuLaser C2600N Printer
My Epson Aculaser C1100 shows 'change toner K'
I've just replaced the the Yellow and Magenta colour toner based on your fantastic advice...
Jul 17, 2012 | Epson Aculaser C1100 Printer
The waste toner cartridge has a transparent extrusion on the bottom, which fills with toner when the cartridge is full, but also if it is half full and shaken so that toner falls into this extrusion. If this happens, the only way to remove the toner is to open the cartridge by removing the tape, taking the two halves apart and shaking/blowing/hoovering it empty. You can stick them together again with ordinary sellotape.
Jun 17, 2009 | Epson Aculaser C1100 Printer
Prints in black are poor quality
fist of all reunisall your printer driver ....
if problem dose not fix .
it means black colour laser section have problem so you can clean lens of laser if posible and replace laser secaner.
Apr 29, 2009 | Epson AcuLaser C4100 Printer
Epson Aculaser Need to bring faulty cartridge to front
On the LCD display choose the 'Reset Menu' Then within that menu keep going through the options till you get to 'Change Toner M' (if it is Magenta). Once you select the appropriate 'Change Toner' it will rotate to offer the correct toner.
Apr 06, 2009 | Epson Aculaser C1100 Printer
Imagerunner 2016, waste toner full error message
hey, wel if the copier is showing a message saying that the waste toner is full it means the waste toner deposit is attached to the drum unit.
so, open up the frotn cover, pull down the (drum)-lock lever, it should release the left cover, then pull towards you the drum unit, and there you go.
the black case with a small trasparent cap is the waste toner deposit.
you have two ways to go.
1 you may remove that rounded transparent plastic cap and be able to vaccum the waste toner (dont even try reusing that toner, it wont work ok) or
2 you can go the other way wich allows you to easily vaccum it: remove the drum (the roller itself) then the charger roller, then the cleaning blade and there yo go again, but now you got more space to vaccum and believe me it is easier this way.
an additional choice would be to buy a new drum unit gpr18 i think (check please) and forget all about vaccum-ing.
Jan 23, 2009 | Canon imageRUNNER 2016 All-In-One Laser...
Black Cartridge just changed, but still says K-toner low
The only way to clear the message is to wait until the the display shows XXXX Toner Out, then change the cartridge and the message will clear itself.
May 18, 2008 | Epson AcuLaser C4000 Printer
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
Jan 20, 2008 | Epson Aculaser C1100 Printer
Black toner low Epson Aculaser CX11NF
Try powering the unit off and on. The toner indicator does not always reset immediately in my experience
Nov 02, 2007 | Epson ACULASER CX11NF All-In-One Printer
Epson Aculaser C1100 Printer Logo
383 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
