Question about IBM ThinkPad T40 2373 Notebook
Discharges battery after being turned off.
Battery light stays lit after shut down and eventually discharges the battery
completely.
  • 3 Answers
The battery light on a notebook only uses .07 volts to light up and very minnium current.Your battery light isnt discharging your battery.Something called internal resistance is what is discharging your battery.If you are gonna park your notebook for a while and not use it. Take the battery out of the notebook. You will experence less battery drain . But a battery that is getting old may have drain even when not installed in the notebook.Try running the battery compleatly out of juce then charge it 24 hours then do this several times in some battery types this will help them hold a charge better. I hope I have been some help I own Kips Computer Service in Hattiesburg,MS. My e mail is pinebeltrecords2@aol.com feel free to e mail
Posted on Nov 10, 2007
Battery discharges when key turned
The battery may be defective. It will charge but will not hold the charge.
Aug 26, 2016 | 2006 Kia Sedona
Can the car alarm kill your battery but you can start the car but after you turn it off battey died again
sure, if you let the alarm drain the battery, this can destroy any stock battery.
The car batteries are not like golf carts and are not deep discharge rated. (so can be damaged)
so charge the battery, if it wont hold a charge, it is bad.
if it discharges silently, and darkly parked , that is phantom discharge
if is discharges , driving that is a engine charge system failure.
parked over night discharging is phantom discharging.
if the alarm goes off and stays in alarm , then dont use, it.
if the battery is happy with the alarm defeated then the Alarm is bad.
The battery measure 12.6vdc charged,(rested) "voltmeter"
and running measures, 13.3 to 15vdc at idle.
this one tool can solve this problem
http://www.walmart.com/ip/Equus-Innova-3721-Battery-and-Charging-System-Monitor/15137663
cheap.
Dec 05, 2014 | 2000 Chrysler Cirrus
Battery won't stay charged
1. the car drain's the battery even when it is not started or the key isn't in ignicion, the car has a electrical problem, you left a light, the starter could drain it, the alternator as well, or a bad radio is draining the battery even with no key in the ignicion,
2 it's a bad battery (discharges it self by beeing counicated inside).
solucion 1. to see if the car is drainin the battery would be by disconecting a battery termina and see if discharges again, if not, then the car drain's the battery.
solucion 2. if the battery discharges even when if it's disconected from the car, then change the battery.
warning, the first cause coul'd induce to a self discharging battery. even if you changed the battery, do a litle monitoring to be sure it's not the car that is turning the battery bad. how? if you install a new battery, leave the car for a few days (i mean do not start the car) and see if the battery discharges, if so, then you have to search what is draining the battery (that could be a very costly work, time and money and complicated). or put a ''battery disconector'' so the car cannot discharge the battery.
Apr 05, 2014 | 1994 BMW 3 Series
Battery keeps draining when car sits for several days.
Try this to see if you can find the drain: Wait until the car has been off for a half hour, so computer is in sleep mode. Open hood and remove underhood light bulb. Take off negative cable from battery and hook up a test light between cable end and battery post. If you have a drain, bulb should be brightly lit. Start removing fuses one by one until light goes off. When a fuse is pulled that turns light off, that is the problem circuit. Check everything on that circuit to find what is staying on.
Jan 23, 2013 | 2002 Lexus RX 300
Why does my 96 Cadillac Eldorado battery keep discharging?
First step have the battery tested, a bad cell can cause a internal drain and kill the battery, if the batt is ok then check for interior lights like visors that stay on or interior light that come on by themselves at night due to defective door switches.
Dec 27, 2012 | Cars & Trucks
Phone won't shut off. Display stays lit all the
The software got stuck whil shutting down. Try resetting it to factory defaults after saving your phone book and other valuable info on there.
Jun 26, 2011 | Samsung Cell Phones
Battery gradually discharges unless forced to charge
something is wrong withe your lighter so unplug it when the car is off also you may want to do a complete charging system inspection on your vehicle
Jan 06, 2010 | Garmin nuvi 205W GPS Receiver
Failure of the battery to charge while in the home cradle
Wall transformer is bad or was replaced with lower amp unit. Same thing can happen with aftermarket car charger. Possible solution without replacing transformer: turn off LCD backlighting....
Sep 03, 2009 | Tao XM2go Satellite Radio Receiver
Turn On Problem
Are you sure you are actually shutting down and not entering sleep mode? Sleep mode does use power while it appears to be off, it resumes instead of powering on. Have you tried removing the battery when charged and allowing it to sit over night or a full day then check the charge level. If the battery discharges regardless of being inserted, then the battery is at fault.
Nov 05, 2008 | Acer Aspire 5580 Notebook
Battery maintenance
you should charge fully then remove power once it is charged.
use it with battery till battery is discharged.
leaving it plugged in all the time will kill the battery.
thanks for rating.
Jan 15, 2008 | HP Compaq Presario V2000 Notebook
IBM ThinkPad T40 2373 Notebook Logo
157 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
