I need a fan motor for goodman AC compressor model #CK-42-1C Serial number 9905596387
  • 148 Answers
Depends on where you live there are supply houses that carry goodman products the motor is a 3 1/2 ton unit or bring the motor to motor shop they can cross reference that number to another motor that would work fine
Posted on Jun 30, 2009
Wiring schematic goodman ph036a serial # 9610058720
Is condenser running? Verify amps to be sure both fan and compressor are operating. Should have 2 wires to compressor and 1 to fan on top of contactor. Then on the capactor (herm) terminal is the remaining compressor wire. On fan and c would be the 2 remaining wires for the outdoor fan motor. Then 1 more wire on c that jumps to the top of the contactor on the other side to which the first fan wire connects. GOOD LUCK.
Mar 19, 2017 | Goodman Heating & Cooling
Goodman serial numbers
Serial numbers are visible on equipment where you see a permanently attached tag.
The tag will also give model number, motor amps, and other information.
Should say serial number or ser. no.
Jun 30, 2014 | Goodman Manufacturing Goodman R410A 14...
I have a Goodman Model CPLE24-1A, Serial # 0207416067. First, can you tell me how old the unit is? Next the fan comes on in the outside unit and it sounds like the compresser trys to start but cant no
Hello, based on your serial number It looks like the unit was built in Feb of 07. If the compressor is trying to start you may either have a bad capacitor or one of the windings in the compressor is open. Start by replacing the capacitor as it is inexpensive, if it does not work than looks like your compressor will need to be replaced.
Jun 04, 2012 | Goodman CKL24AR24 Air Conditioner
CE25-1EB
http://gethuman.com/phone-number/Goodman-Manufacturing-Co
Phone Number
877-254-4729
Press 1 and wait.
Average Wait: 3 mins - Mon-Fri: 8 am - 5 pm
May 31, 2012 | Goodmans Heating & Cooling
When was the goodman model CKL36-LL serical number 0504211625 produced
The first two digits of the serial number are the year (2005) and second pair of digits are the month (April).
May 26, 2012 | Goodman CKL36AR36 Air Conditioner
Goodman model F48F97A76 need to know what the
if your condenser fan motor is not bad. change out fan capacitor
Apr 08, 2010 | Heating & Cooling
My AC unit comes on, but the fan doesn't work or blow air
The condenser fan motor has gone bad... this is a very common problem. Find the specs. on the side of the motor and then get a replacement from Goodman or from a company like www.grainger.com
The fan motor is rather easy to replace, the worst part is getting the fan blades off of the shaft of the old motor. Use WD-40 and be patient...
heatman101
Apr 07, 2010 | Goodman CKL24AR24 Air Conditioner
I HAVE A GOODMAN CK-36-1A AC AND THE FAN IS NOT WORKING. WAS TOLD TO REPLACE THE CONDENSER CAPACITOR AND IF THAT DID NOT WORK REPLACE THE THE CODENSER FAN MOTOR. THE COMPRESSOR COMES ON BUT SHUT DOWN WHEN...
Goodman unit you can use a 1/4 hp or 1/3 hp cond. fan motor but it does sound like a cap. Replace cap first. Its very easy to do just open up panel and replace the silver bullet with terminals out the top. It will say on the side what size it is like 40uf 5uf or something like that. Thats most likely your problem. Russ
Aug 14, 2009 | Heating & Cooling
Goodman 3 ton outside unit fan not blowing
Motor, wiring and/or capacitor. If the sticker on the side of the motor isn't burned off you can get the motor info off that. Model numbers from the motor do little for locating the motor but my help. Best thing to do is get the AC motor specs and look up online (cheapest) or go to a motor shop. The specs you need would be as follows.
Horsepower-Such as 1/4 or 1/3
Voltage-Most likely 240/1 (240vac single phase)
Rotation-CW/CCW looking at the shaft end of the motor
Amps
Frame size
Jul 10, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman Evaporator fan runs continuosly
first disconnect the green stat wire wire could be bad if still runs change the board on the indoor unit pull board and take to goodman store with model number and serial number its under warrenty they will give new one hope this helps also look at dip switches and instructions to make sure ok
Jul 08, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
218 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
