Question about GE Profile Spectra JGBP90 Gas Kitchen Range
XL44 Profile. Oven will not ignite. Top burners
XL44 Profile. Oven will not ignite. Top burners are good. Temprature indicator reads 100 degrees, doesn't change. No gas smell present in oven.
  • 1 more comment
  • dorisloan Jun 30, 2009
    There is no oven knob, all is electronic.
  • dorisloan Jul 01, 2009
    Hi; how to remove the oven floor? Hopefully, just a couple of screws? Otherwise, cannot see if glow is present. I'm guessing this fix isn't going to be manicure friendly :-)
    GE XL44 oven will not heat. Top burners are fine.
    Genius:
  • 1,847 Answers
The oven doesn't heat, but the broiler works.
I think the problem is the igniter has failed.
That is a very good possibility. The oven ignitor is the most likely component to fail in such an oven ignition system. And yes, it is possible for an oven ignitor to glow and still be defective. You can read about how the different types of gas oven ignition systems work and some of the problems that experience at the following link:
LINK > http://www.appliance411.com/links/jump.cgi?ID=823
Thanks
Kindly rate the answer
Kevin
Posted on Jul 01, 2009
  • 508 Answers
You haft to get thermocouple hot enough to activate valve it is next to pilot lite hold in oven knob to lite pilot lite if it doesnt work replace thermocoupler!!!!
Posted on Jun 30, 2009
    President:
  • 2,187 Answers
The oven that you have has the electronic ignition system (please correct me if I am wrong), where most likely is the cause if the problem.
The way this works is power flows from the thermostat or electronic control through the ignitor and heats it. They are all in series. It then allows a specific amount of current to flow to the oven valve. Once a certain amount of current is reached, it opens the valve and allow gas to flow to the oven burner where it is ignited by the hot ignitor.
This could be a faulty thermostat if there is no current from the thermostat going out to the system and the valve. You may want to open the bottom of the oven (inside the oven) and see if the ignitor glows (which may cause th temp to rise to 100 degrees. If it is glowing, the issue could be in the valve.
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE XL44 model # JGBP30GEP oven. In the "Bake" setting, the bottom burner works, but the top does not. When "Broil" is on, the ignitor ignites the burner fine. Why does the...
Sorry to read about your problem, I hope this helps you out.
that is normal, it bakes from the bottom
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE Spectra XL44 gas stove,but I'm having problems with the oven heating up.Sometimes after several attempts I get the oven operating, but most time stops at around 100 degrees. All of the top...
Yes, I think that you have a problem with the ignitor on your gas range.
As crazy as it may seem the ignitor can light your oven and then the power going through it drops off too much and it will shut your gas valve off. It sits there and goes crazy trying to relight all the time and never gets your oven hot. Sometimes it will and sometimes it won't... Drove me nuts the first time my own oven did that a few years back.
Here is a tip that will help explain it also. At the bottom of that tip there is also a tip on how to buy partson line.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Jan 28, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Jun 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
HELLO I HAVE A GE XL44 SELF CLEANING GAS OVEN WHICH WILL NOT FIRE UP THE OVEN. ALL OTHER FUNCTIONS ARE OK. THE DISPLAY STAYS AT 100 DEGRES BUT I HEAR NOTHING LIKE I USED TO. IF YOU HAVE ANY IDEAS ON HOW...
it's the oven igniter assembly. runs about $60-70. Easy fix. Take out the oven racks and then the bottom oven plate (two screws are at located towards the back oven wall). The igniter is the middle and is connected by two wires that run below. You'll need to remove the stoarge drawer to access the wire connectors. I found my part at RepairClinic.com. They've always had parts at a great price and locally available.
Apr 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 pilot
I dont know if you recieved an answer yet but this is a fairly easy fix. Open your oven door and remove your bottom oven plate. You now should see the burner element running down the middle. at the rear of the burner element is the ignite r (small porcelin bugger with two wires) remove this and replace with a new one GE #WB2X9154 available from the repairclinc.com website for 69.80 plus shipping. i just ordered (2) they seam to go out like clockwork every 2-3 years. To be safe unplug your ovens 110 volt cord first.
Good Luck
Jim
Aug 05, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Oct 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
167 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
