Question about Philips 32PFL6704D 32 in. LCD TV
The remote control works sporadically and when the TV is turned on or is bumped, the menu and volume displays flash on and off on the screen. What can I do to fix it?
  • 410 Answers
NO, your remote control sounds like it is sending the signals to the TV. Take the batteries out or put it in a drawer to test. If it's the TV doing it itself, then it's a bad remote receiver circuit.
Posted on Jun 30, 2009
    President:
  • 1,734 Answers
Check if you can get a Philips service manual here
Need code for apex tv/dvd combo to program remote
http://www.hifi-remote.com/ofa/apex_help.shtml
To program the Apex DVD player on your Radio Shack or One For All remote, there are several steps involved. Basically you will be using the TV device code 0030 and re-mapping all the buttons. There's several steps to get wrong so I will include lots of error checking so that if you make a mistake you will know where you went wrong. Before you start, you should print off the advanced codes.PLEASE NOTE:This will only work for the AD600A model. There isn't a code in any of the current OFA/RS remotes for the newer models (ie, AD500A, AD660A, AD703A, AD800A, etc)
1. Confirm that you have TV code 0030 on your remote.
(Every remote has this code, I am including this step just for your piece of mind, by all means skip it and come back to it if you have problems).
a. Turn on your DVD player and have is displaying on the TV.
b. Press the TV button.
c. Press and hold the SETUP button (the green P button on R/S remotes), wait for two flashes.
d. Type 0030 and wait for two flashes.
e. Press the POWER button, you should see the VOLUME indicator display on the TV screen.
You have now confirmed that you have the TV code 0030.
2. Re-assign the DVD button.
(On the Cinema 7 remote you will probably want to use the DVD button, on the R/S remotes you might want to chose the AUX2 button. In this example when I refer to the DVD button, I am referring to whichever device key you have selected to control your DVD player).
a. Press and hold the SETUP button, wait for the two flashes.
b. Type 992, wait for the two flashes.
c. Press the TV button, followed by the DVD (or AUX2) button. Two flashes.
You have now re-assigned your DVD button to be a TV button, this is so we can enter the TV device code.
3. Assign the TV/0030 code.
a. Press the DVD (or AUX2) button.
b. Press and hold the SETUP button, wait for two flashes.
c. Type 0030 and wait for two flashes.
You have programmed the DVD button to TV code 0030.
4. Program the function buttons.
(You will have to program every button that you intend to use. Don't waste memory by coding buttons that you will rarely, if ever, actually use. If you don't think you will use the numeric keys, for example, don't program them. If you intend to use the volume controls from your TV or amplifier, don't program the volume controls).
I will walk you though setting the POWER button.
c. Type 994, wait for the two flashes.
d. Press and release the SETUP button. (Don't hold it this time).
e. Type 052 (this is the code for POWER).
f. Press the POWER button, wait for the two flashes.
g. Press the POWER button, your DVD player should turn off.
You have now programmed the POWER button. Repeat the steps above for all the buttons that you want to program.
5. Resetting the DVD device.
In order for "volume punch through" to work, you will need to reset the DVD device button to be a DVD button again. This is only an issue for the Cinema 7, because "volume punch through" only works on the original VCR and CBL buttons on the 15-1994, and even then it will only work with the TV's volume).
c. Press the DVD button twice. Two flashes.
You have now reset the DVD button.
6. Setting up the volume controls.
You have several choices with the volume controls. You can program them with the APEX codes, which will invoke the DVD players volume controls, you can use "volume punch through", or you can manually set the volume controls to operate the device of your choice. In this example I will assume that you want to use your stereo equipments volume controls and that the stereo is programmed to the CD device button. Please replace the CD button with the TV button in this example if you want to use your TV's volume.
d. Press the CD button, followed by two presses of the VOL UP button.
e. Wait for two flashes.
You have now programmed the DVD's volume up button to control the CD's volume up function. Repeat these steps for the volume down and mute buttons.
7. Setting up a Loophole Menu macro button.
If you have the version of the Apex that has the "Loopholes Menu", then you might want to set up a button to take you right there. It saves having to remember the secret steps. In this example I am going to put the macro on the "S4" button, but you can put it on any button you like, just remember that it will be in effect under all devices.
c. Type 995, wait for the two flashes.
d. Press the S4 button (or the button of your choice).
e. Press the following buttons in this order (the button names in paranthesis are the buttons that I suggested these Apex functions be assigned to):
STOP, STOP, SETUP (Program), STEP (Move), PREV TRK (CH Down), NEXT TRK (CH Up)
f. Press and hold the SETUP button, wait for two flashes.
It is important to hold the SETUP key until you see the two flashes in the last step. If you release it too soon, the remote will assume that you want the SETUP button to be part of the macro, which will cause some un-expected results when you try using the macro.
Hopefully you have now successfully programmed your remote to handle your Apex DVD player, now you can enjoy movies from all over the world. if you haven't already visited the un-official Apex head quarters, here's the address: www.nerd-out.com/apex.
May 15, 2015 | RCA Universal Remote Control
Need tv code to program remote
May 15, 2015 | Apex Digital Televison & Video
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
Mitsubishi TV Channel Tuning/Remote Problems
To restore full functionality to your set you must replace the remote that came with set. Universals only control the most basic of functions.
Apr 27, 2017 | Televison & Video
Volume control not working
Most of the time one of the switches under the control buttons are bad on the control panel of the TV.
Jul 05, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
No remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Menu will not display
If the channel and volume visual display was not set up on the menu to display on screen , neither will show up even if either the remote or set front button are used. Make sure that the tv button is selected on the remote to access the menu .If that does not work ,then either the batteries are dead or the remote is dead.If it is you will need a new remote,sadly. Then you can press the m button , select sound and then select "display volume" and check "during adjustment". The channel display settings are found on "features" from the main menu. Hope this helps.
May 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips 32PFL6704D 32 in. LCD TV Logo
141 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
