Question about HP LaserJet 1300 Printer
As paper is exiting the printer going into the upper delivery area, the paper gets crinkled. Is it something with a roller?
  • 390 Answers
Yes i guess so, try cleaning the roller throughly also check if you have any bits of paper all the way through the module
pls rate it it was any help
Posted on Jun 30, 2009
  • 24 Answers
Do you find pieces of 'film' material around the paper exit point? It would be black one side gray they other and resemble photographic film. Next do you have marks of tone that are repetitive down the side of your pages? If you answer yes to either of these questions then you need to have your fuser replaced in your printer.
Posted on Jul 12, 2009
    President:
  • 2,777 Answers
If it happens to every page every time then yes you have a roller problem. If it is extremely humid where you are that can sometimes cause it as well. You may need to contact HP for repairs
Having constant paper jams - the paper does feed and the document prints about 3/4 of the page, but crinkles up before exiting the printer, like the slit where the paper is supposed to come out after...
If the paper is jamming at the exit rollers, you will be need to clean the rubber on the rollers. It gets shiny and does not grip the paper to take it away.
I clean the rollers with Isopropyl Alcohol and the green kitchenlb_icon1.png scouring pads. When the rollers are shiny they often have white/grey markings on them. Keep scrubbing until rubber is roughened up.
Oct 14, 2013 | Brother MFC-7220 All-In-One Laser Printer
Hp 2300d paper stops at exit roller
Probable causes: First have you tried running the paper thru the manual feed tray and see if it stops at the fuser unit.. if so then proceed with checking the exit area of the printer(fuser) and make sure there is no obstruction blocking the path, could also be the fuser actuator, small black arm generally pushes the paper during it's delivery(exitiing) of paper.. Worst case scenario is a paper feed timing issue.. but first check the exit area of the printer and the paper tray.
Feb 08, 2012 | HP LaserJet 2300d Printer
Paper jam at exit
The rollers at the exit area are worn out. They can be changed, in the mean time you can use something like sand paper to rub across the rollers to take the smoothness out of them. That will help them get a grip on the paper as it is exiting.
Jun 02, 2009 | Samsung CLP 300 Laser Printer
Paper is crumpled, toner is not adhering in certain areas
The fuser is shot....this is the unit that uses heat and pressure to fuse the toner to the page. It is primarily when the pressure roller wears that you get crinkling and bad fusing, but I'm sure the upper sleeve has seen better days as well.
These days it is (sadly) cheaper to replace this printer with a new little HP -only around $100 or so.
*please rate me :)
Mar 17, 2009 | HP LaserJet 1300 Printer
HP Laserjet 4M makes accordion folds in the paper before jamming
I have found that with laser printers that have an occasional "crinkle" problem that "fanning" the paper does alleviate the problem ... but it will not if there is an actual feed/hardware problem with the rollers
Mar 13, 2009 | HP LaserJet 4M Printer
Paper feeder jams and crinkles the paper up
there is a set of stripper fingers that kiss the fuser roller and paper is jamming up aginst that area
FIX
Open the fuser section door and front door Look at the fuser roller from exit and front door If there is a wiper pad (slides in on a rod from the side of the machine) remove it and put some fuser oil on it
go to area where you find the paper folding up and observe the stripper fingers for any blockage
If there is some bits of toner on the fingers clean them with a q tip and alcohol
take your finger ( make sure machine has cooled and you have unplugged from wall) and press up against the stripper fingers to se if there is movement (some coiers have a solenoid that activates the striper fingers)
The fuser oil hels keep the fuser roller clean and keeps paper from sticking on rollers
Try the copier if this does not fix i believe you have a problem with a solenoid which will require a sevice call
If you want to observe the paper coming through the fuser rollers and seeing if the fingers activate
ou can trip the safety swithes in the doors and exits and observe
Best of luck to you
Jan 06, 2009 | Sharp AL-1642CS Copier
Printer jam upon exit
Check the paper output area ( around the output rollers) for a small piece of paper. You may need to disassemble the output paper assembly, and clean the rollers, or replace the paper output assembly.
In reality, what you have is one part of the printer trying to "push" the paper, while another part of the printer is trying to "pull", resulting in the wrinkle.. The problem may also be with a paper output sensor being stuck, which is why I suggest you check thoroughly for paper scraps in the output assembly.
Nov 14, 2008 | HP LaserJet 3030 All-In-One Printer
Paper crinkles for fax or copies
either your feed rollers are bad or there is a piece of paper stuck
Dec 05, 2007 | HP LaserJet 3030 All-In-One Printer
Paper Jam E54
The one crinkled at the end on the left door is the problem.
Since it jammed it stops the whole copying process, ( you were most likely doing duplex)
The reasons for the crinkled paper are
1- the fingers or claws at the exit are worn and catch the paper instead of sliding them out.
2- you are copying something that has a black edge and is getting caught on those fingers ( or claws)
3- The rollers at the exit are in bad shape :
anyway check out this link and go to error codes :
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Nov 17, 2007 | Toshiba e-Studio65 Copier
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
HP LaserJet 1300 Printer Logo
98 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
