Oven control overlay
Is it a range or a bulit in oven? Unplug or turn off power to your range/oven. If it's a range, take off the back of the range or at least the control panel area. Remove the 4 screws that hold the control panel in place. You may or may not have to remove the wires that go the the oven control, but if you do, take a picture of them with your digital camera or smart phone. Now, carefully lift up a corner of the overlay using your finger nail(s). Lift it just enough to put the round shaft of a phillips screwdriver between the overlay and the controller. Now start twisting the screwdriver so it feeds itself between the overlay and controller. This will allow it to separate the 2 parts smoothly so the paint won't separate from the overlay.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
F5 means the oven control is bad. Will need to replace control and overlay. Overlay is usually a separate part the sticks onto the oven control. Oven control is also called the clock.
