Question about HP Business Notebook NX9110 Notebook
Compaq NX9100 - Does not turn ON...
I have tried to turn this computer while connected to it power AC Adapter or the Docking Station via the power from the docking station. I have also taken the battery off and tried the same ...
I also have tried to connect a sencond monitor the the external monitor plug and did the Fn key combination.
I can hear the fan but these is no display!
In the front of of the computer I have the power and the HD lights On.
  • 324 Answers
Take it down to bare bones (power adapter, mother board, memory and display). If it still acts the same way, it's probably the mother board. ;o(
Posted on Nov 10, 2007
Asusvivo tab RT mobile dock will not charge
If the docking station fails, but you can charge via the computer, then the station is defective. Check the connections and the power supply to the Doc Station. A power surge may have damaged the power adapter to the station.
Jan 04, 2014 | IBM ThinkPad T41 Notebook
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
Jan 16, 2013 | Dell Inspiron 1545 Notebook
My Dell Latitude D505 will only charge the battery through the docking station. I have used mulitple chargers and none will charge batt outside of the docking station. Any suggestions??
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Aug 25, 2011 | Dell Latitude C640 Notebook
My dell 620 battery will not charge with the power supply, yet it charges in the docking station. The laptop will run fine with the power supply except that the battery will not charge till I place the...
sounds like the situation is with the AC adapter detection. try to restore your BIOS defaults and update BIOS if applicable. Test another AC adapter. If that fails, most likely, this is with the motherboard. You may either get a new board, or just continue to charge it using the docking station.
Dec 31, 2010 | Dell Latitude D620 Notebook
Hi, i have a hp nx7400, it wont start or charge battery. tried with different adapters and with a docking station. when i push on button it will blink 8 times without battery connected, with battery...
Remove the battery from the portable and disconnect the Ac adapter. Press and Hold down the power button for 15 seconds.
Reconnect the Ac adapter only and power on the system. If the system is doing the same . The motherboard on the computer has gone bad.
You can read more on the same on the link below
HP support forum
Thanks for using Fixya
Oct 04, 2010 | HP Compaq nx7400 Notebook
E5500 will not turn on after disconnected from docking station
I just want to know, removing battery and docking station, and just use the ac adapter alone still no power on the laptop? If yes please replace the motherboard.
Mar 31, 2010 | Dell Latitude E5500 Laptop
My Dell Inspiron 8200 will not power
remove the battery and try again with ac adapter
Mar 19, 2010 | Dell Inspiron 8200 Latitude C840 Laptop...
I have a Latitude D630 laptop and I recently purchased a docking station to use with it. I tried my laptop's PA12 Power adapter When I initially connected everything and placed the laptop on the dock an...
Try updating to BIOS to version A16 from Ensure you are not attached to the docking station when flashing the BIOS. Once updated, connect the 90W adapter to the docking station, connect your laptop to the dock, and power on using the docking station power button.
Nov 13, 2009 | Dell Docking Station for Latitude D600
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Docking station fror compaq Evo n610c
docking station for my old compaq armada did not "charge seperately" but did supply power to the pc through docking connector and not through the normal ac input, cant say if they have their own power transformers or not, till i go home and take my old docking station apart. Will the computer not power up when plugged in, it normally will run off ac power even when battery is dead or removed.
May 06, 2008 | Compaq Evo N610C Notebook
HP Business Notebook NX9110 Notebook Logo
78 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
