Question about Dometic Rooftop RV Air Conditioner
I have a DuoTherm unit on my 1989 Cross Country that only runs in the "low" position and shuts off after about 5 minutes. Won't come back on until about an hour later, then runs for 5 minutes or so...HELP!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
Is the unit ducted with a wall mount thermostat? If so, then I would say that you need to check the thermostat. Remove the face plate from the thermostat, there should be 6 or 7 wires, depending on the model. With the thermostat set to high/cool, check for power at the yellow wire and the blue wire. Yellow is the compressor terminal and blue is the high fan. If you have no power at the blue terminal, then you have a bad thermostat. If there is power there, then you need to access the control unit in the air conditioner (remove inner shroud). Check for power at the blue wire at the control unit. If there is power, then you have a bad control unit. The unit is shutting down because it is freezing up in the low fan speed position. You can use a jumper wire on the thermostat to go from the +12 terminal (red wire) to the Hi Fan terminal (blue wire) and also the fan terminal (Either tan or orange, depending on the model). If the fan comes on, then you have a bad thermostat. If not, then you have a bad control unit or the high speed in the fan motor is out.
Hope this helps,
Jeff
Posted on Jul 03, 2009
Ac works fine when fan is on low but fan cuts off after a couple of minutes on high
Bad fan motor. Multi-speed motors have a set of windings for each speed. Your high speed is bad so the only solution is to replace the complete motor. When motors are going bad they will over heat and kick out on the heat safety. As it cools back down it will start again for a short time again until it gets hot again.
Jul 12, 2015 | Coleman Dometic Duotherm Rv Air...
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
2003 Chrysler town & country limited
First try and change the fuel filter. this also happened on a van i worked on. I cahnged the filter and it runs fine now.
Nov 16, 2011 | 2003 Chrysler Town & Country
I have a duotherm rooftop ac. fan runs fine but when comppressor starts it runs for 5 or 10 seconds and shuts down
I'm not familiar with these units so this is very general. Your compressor could be shutting down due to low pressure. You would need to get the refrigerant charge checked. It might be due to an overload tripping, which would then reset itself. If you had a schematic or something to send me I could tell you more.
May 05, 2010 | Dometic Rooftop RV Air Conditioner
DuoTherm rooftop compressor problem
What you are telling us is called shortcyling is caused by possable low refrigerant then the electrical overload is stopping the compressor. overheating can accure.it is best a local serviceman can check it to prevent major part damage.pressure and oil safey controls can cause
simular cylcling problems.
May 02, 2009 | Dometic Rooftop RV Air Conditioner
Tripping circuit breaker
You probably have a dirty condenser coil or the con den ser fan motor is bad or the blades are jam that's why it overheat and shut off by overload.
Apr 20, 2009 | Dometic Rooftop RV Air Conditioner
Dometic/Duotherm propane furnace won't fire up
If this unit has a spark ignition you may just need to clean the flame sensor. It is a metal rod protruding in the path of the flame.
Feb 10, 2009 | Dometic Rooftop RV Air Conditioner
Problem with the thermostat?
I am not sure what kind of air conditioner this is, but it is possible that it is low on refrigerant. This would cause the line to begin to freeze. When the line starts to frost over the anti freeze protection will shut the compressor off until the frost goes away. Then the compressor will turn back on and begin the same cycle until the refrigerant levels are corrected.
Jun 14, 2008 | Goldstar R5208 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
136 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
