Question about Health & Beauty
I am having trouble shaving my cats fir, the clippers are about 2 years old but hardly used also there is a plastic screwon the side, I was wondering if anyone knows its purpose.
  • 448 Answers
If your clippers have a large plastic (or nylon) screw on the side, they are probably magnetic (as different from pivot motor or rotary motor). With the clippers running, turn the screw in (clockwise) until the clippers make a lot more noise. Then turn the screw back out until the noise significantly diminishes. Go out another quarter turn and they should be set to run correctly, although this may not be your problem with cutting.
Good luck.
Posted on Oct 03, 2009
  • 508 Answers
Screw for brushes oil shears with lite oil duct tape cats feet and shave!
Posted on Jun 30, 2009
Want to use plastic attachment. What blade do I need to use with theses?
Oster 76 clippers can be used with a variety of blade sizes and combs. shaveroutlet.com has many in stock. When using comb attachments, you should use one of the following size blades; 000, 0000, 1, 10, 15, 30
ShaverOutlet com Search results for oster 76
Feb 25, 2016 | Oster Classic 76 Clipper w/ Detachable...
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
What is the best beard trimmer for styling and sensitive skin?
Yes, you are right! Now a days most of the people are using electric shaver because of its advantages like:
  1. It gives a fast shave.
  2. It is cheaper than manual shaving kits
  3. It gives a smooth shave and also there is no chance to get cut or skin irritation
If you are looking for beard trimmer than i will let know that trimmers are used to cleaning up the edges. I would recommend you to use clippers rather than using trimmers because clippers are used for doing the bulk of a haircut.
Aug 16, 2014 | Panasonic ES 8077S Electric Shaver
I have an A5 clipper, with three blades. I have had difficulty with this clipper, ever since I bought it. I have a schnauzer with very fine, soft hair, a bouvier, with very thick hair, and a Lakeland...
hi, on some ocassions when the clippers get hot the metal gear shaft moves meaning the movement of the clipper is limited, you can remove they gears in the gearbox when its hot and see if there is any side to side movement.
Nov 26, 2010 | Oster Golden A5 2-Speed Universal Motor...
Difficulty shaving Spanish Water Dog
The biggest issue with clipping animals (except sheep which use completely different clippers) is that once you have sharpened blades, you need to go slow and keep then blades oiled and cooled. The KOOL spray by oster works great and the clippers you are using are a good reliable brand and model. When clipping my cocker/schnauzer cross, I have a 1/2 inch guard on it (have to use a 30 or 40 blade with the guards) and it takes about an hour. I stop every 10 minutes or so to let them cool down, spray and oil them.
May 30, 2010 | Oster 76076-010 Hair Trimmer
A5 dog clipper or blades may need tune up or
some times the link and gear inside the front part of the clipper wears out and the blades just wont cut. try this, remove the clipper blade on the front of the clipper their is a lever color red grab this part with your 2 fingers and move it side to side if it moves and feel sloppy your gears and link are worn out. you need to replace, also check the hinge for spring tension. if you need help Contact mannyssharpening@yahoo.com
Feb 22, 2010 | Oster Golden A5 2-Speed Universal Motor...
Drum runs rough on spin. Plastic shavings in the
It is plastic of the outer drum that is being shaved off by the inner drum due to it running off center.
To replace the bearigs is a major undertaking, as it involves a strip down.
Dec 20, 2009 | Tricity Bendix AW1000W Front Load Washer
A rattle problem with my Oster Golden A5 Clipper!
The screws on the side of the housing don't serve any purpose other than keeping the brush and spring in the clipper. You can send your blade in for realignment or call 800-830-3678(factory service) and they will help you with all your issues.
Apr 13, 2009 | Oster Golden A5 2-Speed Universal Motor...
How to use clipper attachments...
Used against the scalp, around the ear, on the left and right side... working against the growth direction from behind the ear to the front of the ear.... The angle of the back of the taper guide comb makes it easy to create a smooth, progressive, natural taper along the edge of a men's clipper cut. Do this after you have used a regular guide comb to take down the general perimeter length and you will have a nice tapered edge to the clipper cut around the ears.
May 28, 2008 | Health & Beauty
Health & Beauty Logo
83 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
