Thermador SC302T Electric Double Oven
Problem for Thermador SC302T Electric Double Oven
Thermador SC301T oven
By Ikneedhelp on Nov 08, 2007
Display went dim--can you help
Clarification Request
Posted by sandiann1 on Apr 14, 2009
i got the parts in the 31-7220 is 680 uf ---alot bigger than the old part. the old part is 68uf. is this the part we should put in or this this wrong. thanks
Posted by sandiann1 on Mar 14, 2009
mcm didnt have the part nujmber you quoted? is there a different number? thanks sandi
Same Problem
May 03, 2009
-   I was able to get to the 470 uf behind the display... you just have to be careful and bend the display slightly. This still did not fix my problem. Are the capacitors on the control board that attaches to the display board that actually mount on top of the oven bad also? I can't get this board and I really don't want to pay $500 when I could solder in a cheap part and get it fixed. Anyone replace any other parts to fix this problem? There must be a reason they want to sell you the display board and the control board to fix the problem.-   Edster1
May 01, 2009
-   The problem is the same but the leads for the second 460uF capacitor are behind the display and can't be reached. -   frozenpizza
Apr 21, 2009
-   Okay, I have the same problem and just replaced 3 capacitors on the led board. two were 470 uf and one was 220 uf. I replaced them all and the display is still dim... actually doesn't appeared to have changed at all. I noticed a fourth small capacitor on the board on the opposite end as the other three. I don't recall what size it was, but it is much smaller. Anyone else have a fourth capacitor. I think my model is S301.-   Edster1
Apr 13, 2009
-   I have the same dim display problem as stated above. Since this is a design flaw, I am very puzzled as to why a company like Thermador 1. doesn't fix the problem for everyone through a service recall, 2. doesn't address the problem with more heat resistant capacitors in the new boards, and 3. does not at least provide new boards at cost. It's just plain bad product support.
I was looking at following the instructions below that were very kindly provided by bonanzapilot, but as noted by by sandiann1, MCM does not have these parts. I have tried to find the same specs capacitors on other sites like tedds.com or newark.com but I cannot locate the exact same spec parts. Is it possible to use parts with slightly different specs - for example a capacitance of 470uf instead of 450uf, all other specs being the same?-   mlorin
Mar 14, 2009
-   i just tried to order parts from mcm and it was not a valid number. is there a different part number? thanks sandi -   sandiann1
Best Solution
posted on Apr 16, 2009
Very Helpful)
mlorin
Rank: Apprentice
Rating: 100%, 1 votes
For the 35V 68uF 105C capacitor, I have ordered part 31-7190 from MCM. That's the 68uF capacitor which I believe is the correct part. (Part 31-7220 is a 680uF capacitor.)
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 30, 2009
Very Helpful)
papamoa
Rank: Apprentice
Rating: 95%, 5 votes
those capacitors no one can find at MCM are available at Newark.com (they are manufactured by MCM & carried on MCM site under different part numbers: 96K0331 Newark is 31-7215 MCM; 96K036 Newark is 31-7220 MCM). Price is the same both places -- very cheap. AND you can't buy the display as a unit anymore as Thermador has disconintued manufacturing it, so it's either pay a big bundle to a shop or get handy w/ soldering!
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #3
posted on Mar 14, 2009
Very Helpful)
bonanzapilot
Rank: Guide
Rating: 96%, 23 votes
Thermador SC301T and SC302 stack ovens have a weakness in the radial capacitors on the circuit board behind the LED clock. They get cooked from heat. Here is the fix: Remove two screws from the control panel, located facing up at the bottom on the panel frame.. open the oven door to see them. The panel is then held in place by push in toggles at each end, pull towards you to remove. Carefully unplug the three wiring harness plug-ins, and check them to see if any wires are loose. Set the panel aside. Remove 3 screws holding in the LED assembly, and again unplug the wire harnesses, examining each for loose wires at the terminal. When unplugged, take the LED assembly to the bench, remove the plastic housing, and with a mini soldering iron and watchmaker's eyeglasses, or hobby magnifier,
identify, heat, and remove two 35v 450uf 105 degree radial capacitors, and one 35v 68uf 105 degree
capacitor. These are ordered from MCM Electronics (google it) and are p/ns 96K0326 and 96K0331.
Insert new parts, solder and clip excess leads. Carefully examine the printed circuit board around the area of the leads you just soldered, as some boards do not have the copper close enough to the hole to make contact. Scrape the green insulation from the conductor near the hole to expose copper and make sure your solder makes contact with the copper and the lead. Use your multi-tester when finished to check continuity from all leads you just soldered and their nearest neighboring contact on the circuit board. I found a loose wire on the harness to repair, and one contact on a capacitor did not have the copper close enough to make contact without extra effort. When all is completed, reassemble. Turn back on power at the circuit breaker. You may get an F7 error code. Off with the power again, wait 3 minutes. Restore power, go to oven and press the OFF position on the glass control panel... hold for 10 seconds, and the clock should now be steady at 12:00. Push clock position, reset clock for proper time. Test oven light on/off. Test bake/temp/convection buttons,
on/off. This is a good fix, and will save you about $469.00 in parts and $500.00 in labor. The new
105 degree centigrade high temperature radial capacitors replace old 85 degree, which fail, and your repair should last. Total parts and shipping costs.. about $10.00.
Was this helpful?
Yes
No
14 people thought this was helpful
Solution #4
posted on Oct 19, 2009
Not Rated)
fataalbert
Rank: Apprentice
Rating: 0%, 0 votes
First, I want to thank everyone with your information to repair the Thermador SC301. If you want to spend the $171.99 and send the part to CG Industries, that is an easier way out.
I chose the cheap route and ordered up a few capacitors, 68 micro farad 50 V, 470 micro farad 35 V and 22 micro farad 35 V. The originals rated 105 degrees would have cost under $3.00 from Mouser Electronics but I spent under $7.00 for the capacitors to get an extra set and I bought the 135 C degrees for the two 470 mf and the 68 mf but decided not to use that one due to the larger size--a couple of mm larger in diameter. I spent $15 for UPS for 2 days delivery and $10 for a Radio Shack 15 Walt soldering iron. I had some electronic rosin solder from before. It was pretty easy to remove the 4 capacitors trying not to overheat and trying to get the excess solder away from the board so you could mount the new capacitor terminal throug the holes on the printed circuit board. It took over 5 hours to research all of this information but I was able to repair the board and assemble back in less than an hour. I have had 4 years of basic electronics in high school 35 years ago. Most important is to label all the parts such as harnesses and other wiring and know that the capacitors have a polarity indicator printed on the jacket and be sure to mount this correctly.
Comments:
Oct 19, 2009
- Sorry, I meant 50 V 22 mf and 35 V 68 mf electolytic capacitors. Not sure which ones were bad but decided since they were very inexpensive, change all 4 of them.........
Was this helpful?
Yes
No
Solution #5
posted on Sep 19, 2009
Not Rated)
theblog
Rank: Apprentice
Rating: 0%, 0 votes
Thank you bonanzapilot, replacing the capacitors worked.
my display is now working
Was this helpful?
Yes
No
Popular Solutions for Thermador SC302T Electric
Questions and Unsolved Problems for Thermador SC302T Electric
Do you recommend Thermador SC302T Electric Double Oven?
Answer
Answer
While trying to clean the display window (for time, etc..) on my Thermador SCD302T oven I... (More)
Answer
what are herman e curtis and the dusky devastators songs
Answer
Thermador range with electric oven model gsc30cvb. Plasma display panel (oven temperature and... (More)
Answer
thermador oven element - seems soldered in place, not screwed..
12 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 24, 2009
Display unit went dim and is unreadable as of 3 years ago
Comment by bthumb, posted on Oct 31, 2008
Entire display has gone dim to the point where it is hard to read at all
Comment by sandiann1, posted on Sep 13, 2008
what part do i need for this problem---display gone
Comment by Guest, posted on Aug 01, 2008
Jen air oven display panel cannot be read
Comment by Guest, posted on May 16, 2008
My oven is almost 10 years old and the LED display was dim and now is unreadable. I believe the only solution is to have the entire display module replaced at cost of several hundred dollars.
Comment by Guest, posted on May 08, 2008
Display went dim - can't read anything.
Comment by thermador, posted on Mar 11, 2008
same problem... ... display is too dim to read
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Thermador SC302T Electric...:
Top Oven Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Oven Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
