Question about Pegasus Technologies Pegasus F1225100BN Series 1000 Shower Only Faucet, Brushed Nickel
How do I remove the balancing spool from the
How do I remove the pressure balancing spool from the F1225100BN Series 1000 Shower Only
What do the 3 screws on the moen L3175 shower faucet do?
Two screws hold the cover plate. Behind the plate on some models you might find 3 screws. The two smaller screws on the left and right side of the valve shut off water to the valve and the larger screw on the right side of the valve is the pressure balance spool. The spool is all one piece.
Sep 06, 2014 | Moen L3175 Legend One Handle Shower Faucet...
No cold water to shower but have it in the sink could it be in the valve?
The shower valve is probably pressure balanced, meaning it is anti-scald. Depending on the make of faucet you either need a new balancing spool or a new cartridge.
Jul 06, 2014 | Home
Can't get both hot water running at the same time. Delta Shower faucet
  • The spool and sleeve, the part of the Scald-Guard pressure balance valve that blends the hot and cold water, is not working properly. This can is caused by mineral deposits that build up over time resulting from hard water. To fix this, follow the steps below based on your model.
  1. Shut off water supply.
  2. There are two types of valves. Choose one or the other below depending on your series.
  • 1300-1400 Series: Remove handle.
  • 1700-1800 Series: Remove temperature knob, cover and handle.
  1. Twist and pull sleeve to remove it.
  2. Unscrew brass bonnet nut.
  3. Remove cartridge.
  4. Soak cartridge in a 50/50 vinegar and water solution for 24 hours to remove any mineral deposits.
  • **NOTE** Unless both hot and cold water supplies are turned on, the pressure balance valve will allow only a dribble of water to flow through the valve.
  • I have put up a picture to make disassembling it just that much easier for you.
Regards, Tony
May 23, 2011 | Delta & Single Handle Shower Faucet
No hot water?
can only get warm water from shower
Nov 23, 2010 | Pegasus Technologies Pegasus F1225100BN...
I just installed a Moen shower valve Model 82910cbn. The cold water supply is on. The shower works when the cold and hot water is going to the valve, but when I turn off the cold water supply going into...
This is taken from the Moen manual. You can download it here:
http://www.moen.com/shared/pdf/instruction_sheets/ins162e.pdf
Balance Spool Maintenance
The precise and instantaneous pressure control illustrated has been
achieved through the balancing spool, which has been manufactured to
exacting tolerances.
During construction or valve installation, foreign material such as solder
flux, pipe cuttings sand, dirt or wood is unavoidably introduced into the
water system. Occasionally, however, rare, these foreign materials can
cause the balancing spool to become stuck temporarily between the
rough-in and trim-out operations. If this happens, it will be apparent at
the trim-out test, in that the valve will deliver only a small trickle of water
or it will deliver only hot or cold water. If this occurs, proceed as follows:
1. Make sure that both the hot and cold water service lines are ON. Also,
make sure that both screwdriver stop-check valves are open. The valve
WILL NOT OPERATE unless both supplies are ON.
2. If the valve still does not function properly, turn off both the hot and
cold supplies and remove the balancing spool, using a wide blade
screwdriver. The inner piston of the balancing spool should shake
back and forth freely. If this is not the case, jar the spool on either
end to remove the foreign material and free the spool. When the
spool is free, replace it; turn ON both water supplies and the valve
will function properly. If you are unable to free the inner piston,
replace the entire spool.
Oct 16, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Can't get cold water
the balancing spool sounds like it is frozen. You need to replace the cartridge. The spool needs to move freely to regulate the water coming through it to keep from scalding a person.
Nov 20, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Problem is it's low flow fixture. has low flow resriturer inside
this could a filter in the head that is doiog this just take it out,if this does not fix the problem check the cartridge it may have trach in it or the shower body itself.
Jul 15, 2009 | Pegasus Technologies Pegasus F1225100BN...
No water pressure on Pegasus kitchen single handle faucet
Those new faucets generally have a lower water pressure due to legislation passed in 2007 that reduced that maximum allowable gpm (gallons per minute). I hate to tell anyone this but there is little if anything you can do. First of all, make sure the shut-off valves are open completely. I know that sounds elementary but I've seen it a bunch of times.
Also check to see if the aerator is blocked with a bit of debris.....unlikely if the flow is uniform but still an easy fix.
Hope I didn't break your spirit too much....
Apr 28, 2009 | Pegasus Technologies Pegasus F1225100BN...
Single handle pegasus kitchen faucet. No water pressure when turn
Kitchen faucet? Remove the internal parts and check for blockages.
Apr 05, 2009 | Pegasus Technologies Pegasus F1225100BN...
Hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Nov 17, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Pegasus Technologies Pegasus F1225100BN Series 1000 Shower Only Faucet, Brushed Nickel Logo
324 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
