Maytag 9706AAE - problem is that during any spin cycle, the drum shakes violently to the point where now it seems to tilt and stop very easily. Are the springs worn out? I've taken the front panel off to clean the inside. Did not find anything unusual inside except for some rubbing marks on the side panels from the top part of the tub making contact. How stiff should the drum be in place? Right now, I can move it side to side with very little effort using my hands.
It sounds like there may be an issue with the balance of your washer. When a washer is out of balance, it can spin violently and cause the machine to reset. Here are a few things you can try:
Make sure the washer is level: Use a spirit level to check if the washer is level. If it is not, adjust the legs until it is.
Distribute the load evenly: Make sure the load inside the washer is distributed evenly. This will help to keep the washer balanced during the spin cycle.
Check for foreign objects: Make sure there are no foreign objects in the drum or the drum's seal, which may cause the washer to vibrate.
Check the suspension: Inspect the suspension system, which supports the drum and keeps it in balance. If the suspension is damaged or worn out, it will need to be replaced.
If the problem persists, it's best to contact the manufacturer or a professional technician for further assistance.
I had this problem with my front loader as well. It is probably the mounts or "level shocks" on the bottom of the unit under the tub. I have a Kenmore by Frigidaire and had to replace the "level shocks". I only paid about $43.00 and was not that hard to put on. Look under your machine and see if the shocks are connected to the tub. Check under the top panel also to see if that particular model has mounts up there too.
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
assuming it is a front loader. Check if transport bolts are not still attatched. If not, open back cover and look for shocks for breakage or being siszed. Do you have a noise from the drum while spinning and having no load. If so, the bearings need to be replaced.
its probably because of the way the clothes are in it. you have to make sure the clothes arent leaning to one side and that they are evenly set up. otherwise when it goes into the spin cycle itll lean and hit the side of the washers inside and make it shake and do what you said it was doing.
On something like this you will need to remove the washer wrap to
inspect the suspension springs & base assembly. Please see the link
provided for accessing the inside of the washer. Be sure the shipping
pins have been removed. The tub should float freely.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Remove top of machine and check the centralising springs are still attatched. If springs ok tilt machine against the wall after unplugging from the wall socket and check the shock absorbers. One of them could have jumped out of the guides. If shockies are ok, check the spider for cracks/breaks. The spider is the cast part that holds the outside drum in place. To check this you will have to remove the back plate.
