Question about Kenmore Washing Machines
Stackable washer and dryer. The washing machine tub is tilted to one side.
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
HOW TO CHANGE BELT ON MAYTAG STACKABLE WASHER AND DRYER COMBO.
Is this an LSE series Washer/Dryer?
The two units are separate, joined only by a plug and socket at the rear of the washer. There maybe Sellotape on the sides of the washer holding it onto the dryer legs, this was part of the transportation protection, just cut it off.
Disconnect the power, Disconnect the plug and socket.
Pull the washer forward until you can tilt it back to rest on the bottom section of the dryer. The belts are accessible underneath the washer unit.
BUT.. Why do you want to change the belts??
Apr 06, 2017 | Maytag Washing Machines
Stackable washer dryer
there's a water pressure switch that when the water fills the pressure switch gets satisfied and then stops the water and then sends power to the timer or board depending on what machine you have,if the switch doesn't close the washer will just keep filling.the switch could be bad or also there's a clear plastic hose that goes from the switch to the side of the tub,sometimes detergent or or junk that can form in the hose can cause this,i use a plastic tie or a paper clip ,pull off the hose where it connects to the tub and clean it out with the paper clip,if you have an older machine you can blow gently into the hose and you'll hear like a click sound from the switch,if the hose is clear most likely it will be a bad pressure switch.next time send the brand name and model number so whoever is helping you can look up your machine.all washers are not the same
Jul 10, 2013 | Dryers
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
I have a kenmore stackable washerand dryer that is less than a year old... the problem is that my basket in the washer sits crooked like there is a spring or something off... so now i have to wash minimal...
Yes if its less than a year old call for service it will not cost anything. there are supports under the tub that support the outer tub and basket that have come loose
Oct 05, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have a stackable washer and dryer and water leaks out the bottom as fast as it comes in and when i saw it leaking i tryed to spin it to **** the water down the drain instead of the floor and it started...
Chances are that if water is coming out of the bottom very rapidly a clamp or hose has come loose off of the tub or pump. Also, since that is a stackable unit it should be very easy to check. Tilt the machine back and there should be 2 screws or fasteners holding the front panel in place. If it is not a hose the only other thing would be a crack in your outer tub. (It would have to be one heck of a crack too).
Aug 16, 2017 | Frigidaire FEX831CS Top Load Stacked...
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Tilted washing basket (tub) w/ pics
something has broken or come loose that supports the tub.  You need to remove the back or the top to spot and fix the problem.
Mar 26, 2009 | Whirlpool LTE6234D Top Load Stacked...
The water pump won't start.. washer only works on spin
check the pump belt. tilt it back to see underneath or go through the back
Mar 12, 2009 | Maytag LSE7806A Top Load Stacked...
Washer and Dryer
there will always be water inside he machine(between the tubs, and in the hoses, but no so much to add that much weight so you cant move it, i would look to see of perhaps a levevling leg has hit the floor not allowing you to slide easily.
Dec 01, 2008 | Frigidaire FEX831CS Top Load Stacked...
Leaking washer
remove 2 screws bottom front panel pull panel down should drop and can be pulled out of way ckd area around pump also around center shaft where it goes through bottom of tub lest likely hole in tub make sure small hose back left is attached to small connector on side of tub
Jul 10, 2008 | Washing Machines
Washing Machines Logo
43 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
