How to disconnect the saftey switch on pto when backing up
My Cub Cadet has an override feature so the PTO will continue to run even in reverse. If yours is like mine after you turn on the PTO turn the key back toward off about a quarter of a turn and push the button above and slightly right of the key. A light in the button should turn on to show the override is active.
SOURCE: Electric PTO on 1500 series Cub Cadet won't engagewithengine hot
its the electric clutch on the engine that engages the belt to run blades check the centrifical clutch or electric clutch
SOURCE: Cub Cadet PTO will not engage
Do you have a volt meter or a 12 volt test light?..if you do you can see where you are losing your voltage at..but i would suspect the PTO switch is bad..i hope this has helped.....Keith
SOURCE: Mower pto engages when initially started but after
the coil in the electric PTO shorts out when it expands by heat causing it to lose it's magnetic pull and disengages- I hate to say it,but you need a new PTO clutch.
