Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Ihave the cap cover off the craftsman mower tire, how do I finish
There is a greasy retaining ring and washer on the tire that has to come off, I don't really want to pull it too hard and strip it. How do I remove these parts to replace the tire with new rim?
thanks
  • 218 Answers
Hi..my name is Keith..just wipe the grease off..and you can see the retaining clip..and it should resemble a "C"..and it has slots in it..near the axel shaft..and you stick a flat blade screw driver in the slot and pry it up..but cover with a rag rag or put safety glasses on..because sometimes that "C" clip will go a flying..and the rim should slide off...i hope this has helped..if not..write me back
Posted on Jul 02, 2009
Leaking rear axle seal
If has a Peerless transaxle you need a oil seal 780088A. Its where axle comes out housing. Just pry it out and replaced.
Aug 05, 2013 | Craftsman Garden
Remove front tire on lawn mower
Jill,
If the tire has a hole have you considered a Plug?
If thats not an option before you can pull the tire off, there should be a small snap ring holding it in place. please use blocks to block the tires and do the following.
  • Park the lawn mower on a level surface, then place the wheel chocks in front and behind the rear tires.
  • 2Place the jack under the frame at the front of the mower. Raise the mower up and place the jack stands under each side of the frame. Lower the jack until the mower frame sits firmly on the jack stands
  • 3Remove the plastic cap in the center of the wheel by hand; this should expose the snap ring holding the wheel to the axle.
  • 4Pry the snap ring off the axle with the flathead screwdriver. Slide off the washer, wheel and the shim washers from the axle.
    To replace tire follow steps 3 and 4 in reverse order. place shim washers back on and then wheel and then snap ring, etc...
    hope this helps
  • May 29, 2012 | John Deere Garden
    Front tire leaks. How do I remove the wheel for
    Pop the hub cap and remove retainer. You could install a new tube yourself if you didn't want to have the tubless tire repaired.
    Jul 25, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
    Servicing front hubs
    Automatic Locking Hub
    1. Shift transfer lever to the ``2H'' position, then move vehicle forward and rearward approximately three feet.
    2. Raise and support vehicle, then remove wheel and tire assemblies.
    3. Disconnect brake hose from caliper.
    4. Remove caliper locking bolt.
    5. Rotate pad assembly upward then remove pad retaining clip and caliper assembly
    6. Remove brake pad support bracket.
    7. Remove hub cap retaining bolts, then the hub cap, Fig. 15.
    8. Remove housing assembly, snap ring and shims.
    9. Remove drive clutch assembly, inner cam and lock washer.
    10. Using tool J-36827 or equivalent, remove hub nut.
    11. Remove hub and disc assembly.Manual Locking Hub
      1. Shift transfer lever to the ``2H'' position and set free wheeling hub into Free position.
      7. Remove housing assembly retaining bolts then the housing assembly Fig. 16.
      8. Remove snap ring and shims.
      9. Remove body assembly and lock washer.
    Jul 02, 2010 | 1991 Isuzu Trooper
    I want to repair one of the rear tires. How do I disassemble?
    Hard rubber or plastic cap in center to be gently pried off, this will expose a C clip holding the wheel onto a splined shaft. Jack the mower frame up until the tire is off the ground. Remove C clip and then the wheel, being careful keep it, the washers, and the key in order. If you lose the key, which will fall out when you pull the wheel off, axle will not spin the wheel when you put it back together. Note tire can accidentally be put on backwards, so make sure you do not do that or you will rub a groove right through the tire. Mower tires cost more than car tires. Most tire shops can also fix large mower tires.
    Jul 01, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
    My pull cord on my craftsman mower broke and I bought a new cord but cant get the pulley cover off to replace it, how do you do it?
    With all the side screws removed it should come right off. There will be a little resistance, but that's normal.
    Sep 27, 2009 | Craftsman Garden
    Flat front tire need to remove from craftsman 13.5hp ohv riding mower
    Remove the plastic dust cover, remove the E clip holding it on the spindle, remove the spacer/thrust washer, slide wheel and tire of
    Sep 09, 2009 | Craftsman Garden
    Dry rotted tires on riding mower. I can't get the
    Try some penetrating oil around where the rim and shaft meet. Spray as far into the space as possible. Let sit for a little while to let the oil work. You may have to persuade it with a hammer.
    Apr 30, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
    I cannot get the rear wheel off the tractor. Question... the ''square key''... I thought mine was missing & secured another one, but WHAT DO I DO WITH THE SQUARE KEY ? Is the original still in the hub part...
    Here is what my manual says. It is for a 14 hp 42" mower deck. 6 sped transaxle.
    Block up axle securely.
    Remove axle cap, retaining ring and washer to allow wheel removal (rear wheel contains a square key. Do not lose).
    Repair the tire and reassemble.
    On rear wheels only: align grooves in rear wheel hub and axle. Insert square key.
    replace washers and snap retaining ring securely in axle groove.
    Replace axle cap.
    If you send me your email address I can send you a picture as I do not know how to post pictures on here yet.
    Apr 24, 2009 | Craftsman Garden
    Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
    138 people viewed this question
    Top Craftsman Garden Experts
    Wade Mobley
    Wade Mobley
    Jim Parker
    Jim Parker
    Dennis Key
    Dennis Key
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
