Question about Electrolux Ovens
Can not set clock on Simpson La Stella oven - Electrolux Ovens
  • Anonymous Mar 26, 2014
    Auto light is flashing and I cannot get the oven to work
How do i set the time on a Simpson La Scala wal oven
Posted on Dec 07, 2009
How do I remove the door on a simpson la stella wall oven to make cleaning easier
go to your authorized service agent and ask for a parts diagram for the door hinges
that will show small locks that when the door is open can be rotated into the slots of the hinges and lock the hinges open
from there you lift the door up and out of the hinge slots
Jun 08, 2017 | Ovens
I want to remove the oven door for cleaning but not sure how.
Try opening the door about 6" (15 cm) and pull straight up.
May 08, 2017 | Ovens
Simpson wall oven model 2W501W*00. How do I make the oven work? Curently has digital display with 0.00
Try setting time. Not 100% sure how on that model put you can try by going through the timer setings, eventually you should get to a display with the clock showing that you can alter by pressing the + and -. Hope this helps
Jan 25, 2017 | Ovens
Simpson Model la Stella Oven Thermowave not working Fan works and other settings OK
Burnt out element , thermostat or switch, test with meter.
Nov 10, 2016 | Ovens
My oven doesn't work its a simpson apollo and it got 6 buttons under the clock
Hi,just food for thought,is the lights flashing if so you might just have to set the time,if there are no lights flashing has the cooker got a plug check the fuse has not blown.
Jun 08, 2016 | Ovens
I have an old Simpson fabulous 300 bench top stove in our beach house. We are unable to get the oven to work at full power. We have fiddled with the timer dials in the past and always get it going but it...
First of all, thank you very much Lindsay for choosing FIXYA today for your online technical support needs.
I'm Joe, and I will be more than happy to assist you with your service request.
Unfortunately a User's Manual for that particular SIMPSON appliance is no longer available.
However the problem is most likely that your TIMER has been set to AUTO which will prevent the oven from functioning. The timer needs to be set in the MANUAL mode.
Here are a few links to some other online resources which describe the various procedures for setting the clock and switching the timer mode which may help with your particular problem:
http://reviews.ebay.com.au/Things-to-check-if-your-electric-oven-won-apos-t-heat-up?ugid=10000000001213735
http://john.daltons.info/appliances/Simpson%202001%20Instructions.html
http://product.electrolux.com.au/Public/File/14880 (SELECT OPEN FILE)
http://www.simpson.co.nz/FAQs (SELECT ELECTRIC COOKING FOR APPLIANCE TYPE)
http://www.ehow.com/how_7382695_set-timer-simpson-wall-oven.html
Just use your mouse to click on the links, which are the underlined and blue highlighted sections of text just above. This will open a new web browser page automatically for you and allow you to view the information at the websites indicated.
I truly apologize Lindsay for not being able to provide you with the exact support documentation that you requested, but unfortunately on occasion the desired material is simply not available online.
I still hope this was at least somewhat helpful to you.
Good luck and take care.
Joe.
Jan 15, 2012 | Stoves Ovens
How do i reset the time clock on a simpson evolution 912
Can you add a full model number? I am having trouble finding the manual from the information given. From other oven manuals from simpson, it sounds like the clock is programmable when power is first supplied, so unplug the unit, wait a few minutes, and plug it back in. Then press the - and + buttons to set the time. 5 seconds after the last change the time will be set.
Oct 03, 2010 | Ovens
Cant remove glass cover to replace bulb on Simpson La Stella Atlas series oven
I have a Simpson Atlas Mira. Was having a hard time getting the glass cover off too so looked on the net for a solution. Couldn't find one so I persevered and sorted it...
The glass cover has a screw-off thread (like a glass jar) which unscrews anti-clockwise (lefty loosey). I had to give it a good few wiggles and pulls before it would start unscrewing. I also had to use a damp towel to get a proper grip - it's a slippery little bugger - but I got it in the end!
Hope this helps someone - good luck!
JD Hamilton, NZ
Aug 23, 2010 | Ovens
Simpson Apollo can't set clock so oven won't work
I don't know if this will help. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Apr 30, 2010 | Stoves 720EF Electric Double Oven
Ovens Logo
2,356 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
