Question about Graco Baby Gear
Graco Swing wont swing what can I Do ?
I have Graco swing for my grandbaby and the red button to lock it in place dosen't work nor will the swing work with new batteries what can I do?
4 Suggested Answers
SOURCE: Graco swing not working, I'm trying to open the motor box.
You need to remove the center of the part the connects to the chair. Use a thin screwdriver to pry it out a little, slide the screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off.
Posted on Nov 20, 2009
SOURCE: baby swing......graco doesn't swing
We`ve recently bought a 6 speed swing second hand and had exactly the same problem ie it only worked when the swing was empty. We found that if you give the swing a nudge before switching on the motor this sometimes works as the motor only has to keep the swing moving.
If this doesn`t work, strip the motor down and check the contacts. A poor contact will mean that you get less power from the motor. Be careful not to break the connectors on the motor as you take it off as they are fragile. If any contacts appear weak, then they should be carefully soldered to make a strong contact.
Then carefully reassemble the motor on the swing and give it a push to get it going before switching on the motor.
Hope this helps someone reading this.
Ian and Ellie.
Posted on Dec 14, 2009
SOURCE: Where can I get the graco sweet peace swing manual
I found one online: http://media.gracobaby.eu/manuals/Sweetpeace%20UK.pdf
Posted on Jan 16, 2010
How do you turn off a graco open top swing?
www.gracobaby.com/instruction%20manuals/archive/152.pdf
GracoTo add time, push the time button once or twice. To turn swing off, press and hold either speed button briefly.
Jan 08, 2016 | Baby Gear
Graco swing
I'm not sure if you tried a different outlet plug yet, but I would try to eliminate whether if its the power source (outlet) or the swing itself. Also, if the outlet has a reset/test buttons on it, then it might have tripped itself.
Apr 23, 2013 | Baby Care
We need the base to a Graco Sweetpeace baby swing.
Under the "Add your solution or ask for clarification" window click on the camera icon to add photo.
May 25, 2012 | Graco Sweetpeace Newborn Soothing Swing...
How to disassemble graco swing
First, take part the seat. It had buttons and what not so undo them and take it off the frame. 2nd: Take the mobile (where the teddies hang) part by pulling. From there you just pull things apart. You shouldn't need any tools.
I hope this helps a little.
Apr 27, 2012 | Graco Lovin Hug Swing - Erin
I bought a used Graco baby swing (I think from about 2001) and I can't fiure out the buttons. There are four - low-timer- high - music. It has 6 speeds, 15 songs, and time listed on the front. I don't...
YOU NEED THE MODEL NUMBER then follow link below
LOOK FOR THE MODEL NUMBER
  • BOUNCER On the back of the vibration unit, below the battery compartment door
  • OPENTOP™ SWING Inside the battery compartment behind the batteries
  • WIND-UP SWING On the underside of the top housing- the piece of plastic that runs across the top of the swing and is right above the baby's head
  • TRADITIONAL SWING Under swing tray
  • TRAVEL LITE™ SWING On the bottom of the contoured plastic seat
  • SWEETPEACE™ NEWBORN SOOTHING CENTER On the bottom of the seat
  • DUETSOOTHE™ SWING + ROCKER On the underside of the housing
  • DUETCONNECT™ SWING + BOUNCER On the underside of the housing
  • DUETCONNECT™ DLX SWING + BOUNCER On arm with motor hub
  • LITTLE LOUNGER™ Inside leg near Rock Lock
  • DUET ROCKER™ Backside of front plastic panel with Graco Logo
  • GLIDING SWINGS Under motor housing unit (electronics hub on right hand side of swing)
  • SIMPLE SWAY™ INFANT SWING On tubing on bottom of unit
  • COZY DUET™ SWING + ROCKER Under battery hub on back of swing
  • DREAMGLIDER™ GLIDING SWING + SLEEPER On side hub with electronics
Product Instructions Search Results
Jan 01, 2018 | Graco Toys
Graco swing will not swing with 5 month old in it. Put in new bateries everything. But when we take baby out it swings perfectly fine
Same problema as described by other person: Graco swing will not swing with 5 month old in it. Put in new bateries everything. But when we take baby out it swings perfectly fine
Oct 19, 2010 | Graco Toys
Baby Gear Logo
641 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
