Question about Whirlpool Duet GHW9150P Front Load Washer
Leaking soap dispenser
Soap suds come back up through the soap dispener when spin cycle starts
    Problem Solver:
  • 10 Answers
There should not be suds up that high in the washer. You are experiencing a over sudsing condition and spin is throwing up throw the fill line in the dispenser. Run some fabric softener in a load with no clothes to clean out any hidden suds. Then use only HE (High efficiency) detergent and half of what they recommend! The softer the water the less the soap you use. Sounds like you may be using non HE detergent. My guess if the machine is fine.
Posted on Jun 30, 2009
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
Dishwasher suds up and leaks during wash
Suds in a dishwasher usually come from using too much soap or the wrong kind. Soap can build up over times causing problems. First start a cycle.Do not add detergent or any dishes.When it starts washing, pour a cup of vegetable oil directly into the tub. This will cut the existing soap suds. You may need to try this a couple time before the dishwasher will drain. After all suds have been removed, load you dishwasher and start a cycle filling the detergent cup up half way. If it goes through the cycle with no problems, you should be all set. Still have the problem? A rinse aid dispenser that dispenses too much rinse aid will also cause the dishwasher to suds up. You can remove the dispenser from the door, flush it out and reinstall. Make sure you turn the circuit breaker off before taking the door apart. After rinsing it out, do not add rinse aid. Try the dishwasher and see if the problem goes away. I've seen people accidentally put liquid dish detergent in dispensers too. A dishwasher that has suds is apt to leak. Fix your suds issue and you most likely will fix you leak
Dec 27, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
LE LIGHT IS APPEAR
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Nov 12, 2012 | Washing Machines
LE LIGHTY IS PRESENT
My washer is saying LE, what does LE mean? It stopped washing!
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Hope this helps.
Jun 29, 2011 | LG Washing Machines
My washing machine is cannot spin ,it show error code LE
Nov 28, 2010 | Washing Machines
I keep getting a code le why?
Has a large load size been used with a gentle wash setting
Has the washer been overloaded?
Thank You
Sep 10, 2010 | LG WM-2277HW Front Load Washer
Leaking // bleach/fabric softener dispener isnt emptying
Remove the dispenser cup and clean it. Be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Water Leaking From Calypso, Won't Drain Completely
the bag type device is an overflow and should never have "water"in it, but it will get suds if you are using the wrong type of soap.
you need to use "HE" soap as it is a non-sudsing soap and thats why you are getting suds leaking from your unit.
just run the rinse and spin cycle until the suds are gone. then use the right type of soap and it will work properly with no leaks.
Jan 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Could SOAP DISPENSER be caked with soap???
POWDERED DETERGENTS GET CLOGGED ALOT IN THOSE DISPENSERS. I ADVISE CUSTOMERS TO FILL THERE WASHER AND ADD SOAP WHEN IT STARTS TO AGITATE WHEN USING MORE THAN A 1/2 CUP OF POWDER ... THEN ADD YOUR CLOTHES ... THE WASHER HAS A SAFTEY SWITCH WILL STOP MOST WASHERS WHEN AGITATING OR IN SPIN CYCLE,SO YOU CAN LOAD CLOTHES ... OTHER THAN THAT ... ALL YOU CAN DO IS KEEP THAT DISPENSER FLUSHED OUT WITH HOT WATER AFTER EVERY WASH. JUST POUR HOT WAYER TROUGH IT ... IF THE WATER BACKS UP (EVEN WITH A SLOW POURING) THE DISPENSER IS PLUGGED AND NEEDS TO BE FLUSHED OUT WITH A HOSE. GOOD LUCK AND STAY DRY !!!
Apr 29, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
348 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
