22 inch monitor went blank.
22 inch LCD monitor SP2107W bought at Staples. Removed screws but can't separate outside to see inside. Work on and with mac computers and know how to fix just about any problem with them. Warranty ran out and as with many others money is tight. I'm hoping there is just a loose connection somewhere. Sure hope someone can help.
Thank you for your time.
  • 1,684 Answers
LCD moniotrs usually have a latchs around the sides of the case. Use a small flat blade screwdrivers and start at the corner. Insert the blade a little bit between the two halves of the case and pry a little bit. The latches can be realeased when you apply a little preasure to the screwdriver. You should find about 3-4 latches per side. Once you get the first one or two released the others will be easier to open. I have some repair guides on my web site at:
www.ccl-la.com/badcaps.htm These might help you opening your case. You may also want to look at them and see if you have any bad capacitors that are causeing the issues you are having.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair.
Posted on Jul 14, 2009
17" Sony SDM-S74 goes blank after 1 hour
Here is my possibility.
Sorry to be the bearer of bad news but the fact is you have a very old monitor. My research tells me that it is almost 10 years old.
The obvious problem and the one most likely is that the power board inside the monitor is going. It is common in LCD monitors of this age. Do yourself a favor and junk it and replace is with a new larger better monitor. They are so much better these days and so much much cheaper.
You can get a 22 inch wide screen monitor on Walmart.com right now for $104.00 and pick it up at your local Walmart with free shipping. Not advocating Walmart necessarily just pointing out. Recycle your old monitor responsibly and pick up a new one. No matter how cheap it is it will be better than what you have now and your current monitor is not worth a technicians time.
If you don't have the money for a new one go to your local thrift shop and get a working 17 inch for $20. Good luck.
Walmart V7 22 LED Widescreen Monitor Black
Nov 02, 2010 | Sony DELUXEPRO SDM-X73/B (Black) 17" LCD...
When i turn my monitor on it shows no picture and it makes a sound like it is running the electricty went out and when it came back on thats when the trouble started thank you
It's time to spend $100 to buy a brand-new 19-inch LCD monitor,
or $200 to buy a brand-new 22-inch LCD monitor,
rather than paying a TV/CRT technician $50 to $75 per hour to try to fix the "antique" monitor.
Aug 05, 2010 | HP Compaq P 1220 (Carbon, Silver) 22" CRT...
Westinghouse 22 lcd monitor. faint click and went
More likely the filter caps failed and may have taken out the inverter fuse and the MOSFET in the inverter circuits also. yoo need to open it up and inspect the inside, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 09, 2010 | Westinghouse L2046NV Monitor
Monitor went blank and started to make a low buzzing sound
Check the input selector and make sure issue occurs on both input 1 and input 2 video connections.
If it does, there are no user serviceable items inside the Monitor and you will need to have the monitor serviced if you want it fixed. Most likely failure is the flyback transformer.
NOTE: you can get a replacement 22 In LCD monitor for about $150, repair to the P1110 will likely cost more.
Jan 01, 2010 | Dell P1110 21" CRT Monitor
22 inch monitor won't power up, went blank after two years. Power button does not even light up.
It seems to be a HW issue Staright away>
connect it with a diff power cable> see if the same happens > if it does> then the monitor has gone bad
Oct 08, 2009 | Gateway FPD2275W LCD Monitor
Is Staples monitor sp2107w compatible with a Mac? I am ordering a new mac for son in college, on tight budget and need to know if the staples 22'' monitor sp2107w will work for the short term. This is the...
I'm having a heck of a time finding that at Staples.com ... although general searches found stuff about it. Mmmmm do they still offer it for sale?
What's the support like for it? Who really makes it? Because I don't think Staples the office supply company makes computer monitors.
Get him a nice Apple monitor from where you're getting the computer - and have them show that it works. That's my suggestion. (Now I'm saying things backwards like Yoda on Star Wars :-)
Jul 07, 2009 | Computers & Internet
Can't remove cover of Westinghouse LCM-22w2 monitor
Hey Ed,
I hope I can help, It doesn't open from the back, it opens from the front.... carefully! There are four support screws, which hold the LCD screen to the desk stand,after removing all the support screws (4) on the back under the support stand cover.(which pull up to remove) (Remember! the whole case and face frame is plastic, so take your time). Work to separate the black face frame around the LCD from the silver case. Its held together by small plastic clips on the face frame to the wall on the LCD case. Start at one of the corners and slowly pry the face frame and silver case apart. (separate it inch by inch, work your way around the case carefully. If one corner doesn't give, go to another side.
Putting back together works reverse, the face frame and the case snap back together, Carefully! And replace screws (4).
Russell
P.S. I have three LCD models from Westinghouse, LCM-22w2, L2210NW and the L1916HW. They all open the same way.
Dec 07, 2008 | Westinghouse 22" Widescreen LCD Flat Panel...
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
David Payne
David Payne
