Question about Sport & Outdoor - Others
1974 johnson outboard motor 25hp stalls when hiting high end
1974 johnson outboard motor 25hp stalls when trying to plane out boart points caberator fuel pump replaced .motor start and runs ok at three quarter speed but stalls out when hiting high end
  • Anonymous Mar 27, 2014
    needed info on how to replace an impeller in a johnson outboard
    Problem Solver:
  • 6 Answers
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Posted on Jun 30, 2009
Why am I getting Fire on just 2cylenders of my 1974 Johnson outboard
hi Don.
sorry to send you to this link,but there is forums on there that you could go into and see what others are saying about this problem,hope it helps you out.
Fire on just 2cylenders of my 1974 Johnson outboard Google Search
Nov 28, 2017 | Boating
When running the motor the water goes in cold but comes out hot what could my issue be It is a Johnson 25hp out board
Hi Jason:
This ended up in the washing machine section. ????
Outboard motors are cooled by the water that circulates through them. There is an impeller type pump in the lower end that takes available water and pushes it through the engine. This water collects heat from the engine, and the heated water gets discharged. usually through the centre of the propellor.
What you are describing sounds to me like the intended function of the cooling system.
Cheerfuls.
Aug 04, 2015 | Boating
93" 115 H V4 Johnson outboard motor will start and idle fine
your carburetors might be dirty blocking flow to the high speed jets causing it to bog down
Jun 29, 2010 | RTO Outboard Motor Bass Fishing Boat Rod...
1974 Johnson 70 hp outboard, quits on acceleration.
It sounds like your motor is starving for fuel. At an idle, you have adequate flow to keep the engine running. When you call for more fuel...you sputter and quit. Could be a clogged filter or trash in the line or in a jet. Yes you will have some air in the bulb, but not a great deal. You could be sucking air at a hose connection (loosing some prime)...try this, start the engine and slowly accererate, have someone pump the bulb as you accelerate, see if the engine works properly while doing this test.
Aug 27, 2009 | RTO Oar Sockets
1974 60hp johnson outboard won't run on full throttle under load , max 10%. New fuel and filters ect. The motor is old but has very low hours.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Apr 12, 2009 | Boating
Sport & Outdoor - Others Logo
729 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
