Question about Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
One expert says the heating element is bad and the other says the motor? Frigidaire 5.8 Cu. Ft. Electric Dryer Model#: GLEQ2152EE runs 30 minutes, quits, trips the breaker
  • Robert Stewart Jun 30, 2009
    One expert says the heating element is bad and the other says the motor? Frigidaire 5.8 Cu. Ft. Electric Dryer Model#: GLEQ2152EE runs 30 minutes, quits, trips the breaker. Then I get advice for a gas stove?
    Thank You?
    Top Expert:
  • Frigidaire Master
  • 79,865 Answers
The heating element by far is the most common part to cause this, the motor is very unlikely based on my experience of 30 years
Posted on Jun 30, 2009
    Sergeant:
  • 296 Answers
This advice is for GAS ovens with glow bar type igniters. This is a fairly simple repair that MOST do-it-yourselfers can accomplish with just a little guidance. But, first, here’s a little gas oven theory to help you better understand how to determine if an igniter is bad:
The way the ignition system in most of today’s ovens work is like this:
  1. Set the oven or broiler temperature.
  2. The igniter begins to glow.
  3. Once the igniter reaches a certain current potential, the gas safety valve opens.
  4. Gas is introduced into the manifold and you have ignition.
  5. NOTE: It can take roughly 30 – 90 seconds from the time you set your oven temp to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the oven to prevent free flowing gas from accumulating in your home without ignition. That’s why you typically don’t hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
MY FRIGIDAIRE AFFINITY MODEL # AEQ6000ESO WILL NOT HEAT. IT STARTS FINE.
There is a reset on some models by unplugging the appliance and waiting a couple minutes then plug back in make sure timer is on off position and pulled out. You can also open and close the door just alil bit 6 times within 12 seconds while machine is plugged in. But I think you should test ur thermostats and heating element with a multi meter for continuity? A worse case may be that the motor has burned a winding and or ur ur power outlet is only giving half the current as the dryer uses 120 to run and the other 120 to operate the heating? thus if u only get 120 instead of 240 volts you will get an appliance that runs but does not heat.
Feb 06, 2015 | Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft....
How do i fix dryer taking long time to dry
BAD HEATING ELEMENT. I believe that particular model has a ring type heater coil; very effective but fragile. The dryer must be disassembled until you see the entire heater coil, I've attached a photo. The replacement is less than $80 via Amazon Prime, I know, I've done this. The kicker is that the coil was still putting out a little heat but taking forever to dry. You're just asking for a fire or a total breakdown which could adversely affect your control board (not cheap). Hope this helps. 5307dbc3-6273-485b-aaec-414a05b9c79c.jpg
Jul 13, 2014 | Frigidaire FAQE7001LW Affinity 7.0 Cu. Ft....
How do i change the fuse on my Affinity dryer?
Thermistor or high limit switch has tripped; usually due to low air flow from lint build-up or vent blockage. OR, the heating element went bad and a new one can be ordered. In some cases, I have received new thermal switches with the element. It's a job getting the dryer apart and inspecting the element, but you need to know for sure before you have a fire or a control board failure.
Jun 18, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My dryer model dv231aew/xaa Will not shut off unless you open the door....on/off & pause shows its working but its not
follow this steps and fix it. Merry Christmas
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace the heating elements.
Dec 17, 2013 | Samsung DV231AEW 7.3 Cu. Ft. White...
No heat model dv665jw/xac
Element or thermal trip on element, you will need to test them with a meter, as to which one, But if thermal trip gone, why, could be element on way out.
Mar 18, 2013 | Samsung 7.3 Cu. Ft. Electric Dryer
Dryer is very loud and only runs for 5-15 minutes
That to me sound like bad front glides. I recently worked on a Westinghouse dry like your with more troubles than a squirrel on an 8 lane highway. That video and more is on my Frigidaire dryer repair page
Sep 19, 2012 | Frigidaire GLEQ2152EE Front Load Electric...
My frigidaire affinity dryer works but does not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 06, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
DRYER RUNS NO HEAT IS HEATING ELEMENT NEED REPPALCED HOW LONG ARE HEATING ELEMENTS GOOD FOR?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 25, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Have a frigidaire affinity electric dryer that doesn,t heat
check your heating element or the thermal fuses located on the back wall the side of the heating element can and the plastic blower ducting
Sep 06, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
41 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
