Question about Philips PH62080 Uni-Directional Microphone Microphone
The Mic Worked but now It won't
Ok....I got the Microphone and it worked well for about a month and a half maybe. One day I was just recording something and didn't like it so cut it out. When I tried to record again nothing came out. I've tried alot of things. The volume is way up, it's all good. It's in the correct Jack. And it's on. But for some reason, it will not record my voice anymore when it was working fine! Did I bust it? Cuz when I was done with it I tied up the cord around the Mic, leaving a space at the end so the cord wouldn't bust. Did I break it or what cuz everything was working fine.
3 Suggested Answers
marsrover
  • 682 Answers
SOURCE: microphone isn't working with the computer.
1-select start2-select contrrol panel3-select sound speech and audio devices4-select sound and audio devices.5-confirm that mute box not signed.6-pres advanced in mic volume confirm mute box not signed7-select audio you will see capture screen in mic volume sign select.8-in default device press volume you will see volume control screen in mic volume confirm that mute box not signed
Posted on Mar 08, 2008
SOURCE: No Sound Coming out my Microphone
This same thing happened to me. All I did was plug the mic into my keyboard, turned the mic volume to max, and turned the mic on. Then, I grabbed the part of the mic where the cord goes in, and started turning it. I turned it left and started hearing noise come out of the mic. I kept on doing this, until sound came out of the mic. I did this, and now the mic works again. Hope this helps!
Posted on Dec 22, 2008
My microphone is not working. What do I do? Trying to use Skype, but microphone want work
Hi ldlw65,
Please follow the below steps to set up your microphone properly :-
  1. Firstly check if your microphone's cable is in proper order, if it has been damaged, then it's that physical fault which stops microphone from working.
  2. Now if the wire or cable of microphone is OK, check if you have connected your microphone in the correct slot , in your motherboard , usually there is a sign of mic besides the microphone slot.
  3. Then check for the control panel's sound and audio devices option , by going in your control panel, if you open it and go in the audio tab you should see your recording device as enabled.
    If it's disabled then you need to install your audio driver's again.
  4. Now , if everything is ok till here , all you need to do is do a microphone check by going to sound recorder (start >programs>accessories >entertainment>sound recorder )in windows xp , in case you are using windows xp or any relevant software in the other operating system which records audio.
  5. Once you have the application like sound recorder try speaking on mic while you activate the record option , if you see that your sound is being recorded, then your mic is functioning properly, if it's not then you need to check if your mic is the current recording device.
  6. To check if your mic is the current recording device , all you need to do it double click on the volume icon on your task bar and you will have volume control box open , then you need to go to the options menu and choose properties.sajjad4help_2.gif
  7. After you choose properties you will have a radio button for recording , select it and you will find devices for recording , then make sure microphone is selected and click ok.sajjad4help_6.gif
  8. After you select ok , then you need to select microphone from the recording options to activate recording via your microphone.sajjad4help_7.gif
Now you should be able to use your microphone properly without any problems.
Your feedback would be appreciated.
Hope this helps ..)
May 13, 2011 | Toshiba (P000257700) Microphone
Got a MacBook Pro...problem recording with external microphone
Hi
... sound issues like you are having do pop up occasionally ... the best thing to do is to reboot the system ... sorry.
Cheers.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ronald_f3c54257e2cc2559
Apr 29, 2017 | Apple GarageBand Jam Full Version for Mac...
Suddenly MIC port is not working...
go to volume control option and select mic advace option and choose microphone boost option and try.
Jan 20, 2010 | Gigabyte GA-K8VM800M Motherboard
I want to know if my acer aspire 9410 has a bilt in microphone. if so how do i get it to work.
Look up Sounds (is on control panel on Vista), then look on the Recording tab (if there is one) - your microphone (and maybe a line-in) will be listed. If you look at its properties, tab "Levels" make sure it's not muted (toggle mic picture) and the volume level is up some (can be half way).
Another way to get into the Recording tab is to look for the speaker icon in the system tray, right click on it, and select "recording devices".
Try the mic out by loading some software that uses it. Skype can help (need internet), if you load it up and use the "Echo / Sound Test Service" you can hear if your microphone is working.
Sep 13, 2009 | Acer Aspire 9410-2028 Notebook
Cannot get microphone to work while connected to computer.
I found this on the Turtle Beach website: ________________________________________
Let's make absolutely sure that the microphone in your headset is working correctly. If the mic is working, a replacement talkback cable should fix it. If not, then please send in your name, shipping address, the name of the store where you purchased your X1 and the date (month/day/year) of purchase.
OK, here's how to test the X1 using the Microphone input on your PC:
1) Take the pink plug from the X1 and plug it into the pink jack (Microphone input) on your PC's soundcard.
2) Take the green plug from the X1 and plug it into the green jack (Front L/R Out or Line Out) on your PC's soundcard.
3) Take the USB plug from the X1 and insert it into a USB port on the PC (not a USB hub, please).
4) In the soundcard's control software, enable the Microphone for playback. In the Microphone > Advanced settings, enable the Microphone Boost. Make sure the Microphone is not muted (Mute switch is not enabled).
5) Adjust the volume for the Microphone to about half-way up.
6) Adjust the overall playback volume to about half-way up.
7) Put on the headset. Make sure the Mute switch on the X1 amp box is not set to Mute (the LED should be green).
Now speak into the microphone. Do you hear your voice in the headphones? If so, the mic works and your X1 headphones should be OK. If you still cannot get the X1 mic to work over Xbox Live, then you need to take a closer look at Dashboard settings and other connections, or check the integrity of your X1-Xbox Controller Cable.
In order to enable the chat make sure that the Mute button in the Off position. If it is on the ON position the Mic will not work.
Red = Muted Green = UN-Muted
_________________________________________________________________
If you're having trouble adjusting the Mic in Windows:
WINDOWS XP:
For Windows XP, there's a nice video on YouTube that takes you through all the steps of setting up your microphone: http://www.youtube.com/watch?v=Vissxo8furo
WINDOWS VISTA:
Please follow these instructions to configure your microphone within Windows Vista:
1. Left-click on the Start button. The Start Menu will appear.
2. Left-click on Control Panel. The Control Panel will open.
3. Left-click on the Hardware and Sound option. The Hardware and Sound window will open.
4. Left-click on the Sound option. The Sound window will open.
5. Left-click on Recording from the three tabs at the top of the Sound window. While in the Recording tab of the Sound window, you will see all options available for recording - Microphone should be one of them. (If you don’t see an option for Microphone, ensure your microphone is plugged into your computer using the jacks commonly located on either the front or back of the machine.)
6. Left-click on the Microphone option to highlight it. This will enable the Properties button toward the bottom-right of the window. Left-click on the Properties button.
7. You should see the Properties for your recording (input) devices. One of these should be Microphone.
8. Left-click on the Levels tab (or similar). Adjust the Level (Volume) and Mic Boost controls to at least half-way up. If your Mic Boost control is a simple check box, please make sure it is checked (Enabled). You should hear your microphone in your headset or speakers.
Once the levels are adjusted to your satisfaction, left-click OK and OK to save your settings. You can then close the Control Panel.
Your microphone should now be ready!
Apr 17, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Cannot get laptop microphone working
Double click on the little speaker icon on the Desktop toolbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure he microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder or whatever application you are using and try to record. If this does not work I would get an external microphone plug it into your laptop and try recording again. If the external mic works then I would think that you internal microphone is not working. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 16, 2009 | Compaq PC Microphone (Black or Beige)...
Microphone input on Dell Inspiron B130 doesn't work
Your jack may have been damaged, or the apple mic may not be compatible. Purchase another pc compatible mic to check. Or you could try a multimedia headset with mic that plugs into your usb port. Take a look at RadioShack for headsets, I saw one in a store near me. and they should have them online.
Jan 27, 2009 | Dell Inspiron B130 Notebook
Samson co1u recording issue
you first 3 people are idiots... maybe if you had worked with the hardware you would know how the mic works because its obvious you don't. The 4th person is correct because this is exactly how i use the mic and it captures sound in stereo format beautiful when set up rite. Using it in mono, whether use keep on one channel or two drastically reduces the crisp sound that this mic can record.
Mar 18, 2008 | Samson C01U - USB Studio Condenser...
Microphone can be detected but doesnt work
Go to start then control pannel then sounds and audio devices. Then in in the volume tab select advanced in the device volume section. When the mixer comes up go to options then properties select the recording option a recording mixer will come up make sure to check the microphone box. Raise the level in the ixer and you should be golden. If you want to hear the mic select playback mixer and raise the mic level. Hope this helps. : ]
Dec 09, 2007 | ASUS P5RD1-VM Motherboard
Problem recording in stereo
Most likely you have a problem with the MIC. Has this ever worked with this unit? If not maybe the un it is not compadable with this Mic. The instuctions and specs are available for download Here http://esupport.sony.com/US/perl/model-documents.pl?mdl=ECMDS70P&LOC=3 Good luck
Jun 12, 2007 | Sony One-Point ECM-MS907 Consumer...
Philips PH62080 Uni-Directional Microphone Microphone Logo
124 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
