Advent 7203 laptop wont power up
Ive removed the battery and pressed to button to remove any static and also replaced the batter y and plugging in the power but again nothing.. Any idea;s
  • 197 Answers
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Posted on Jul 01, 2009
My Acer Chromebook 13 will not power on or charge so can anyone help me with my problem?
try this: remove battery, remove power cable, push and hold down the power button for 1 m (over 60s) do not short time. release the button, insert the power cable. wait 10s then push and hold power button till you see any lite flash release and see if you boot.
some time the static is built and that causes failure to start.
above should clean any static and allow reset of power adapter to function. if yes,. then once you shut down . insert the batter and ;et it charge for 3 mins.. then try to start.
Apr 02, 2015 | Acer CB5 311 T9B0 Chromebook 13 3 inch...
Stuck sleep mode
The solution to no post on a computer is to remove everything that you can, take out the hdd, the ram, and optical disk and see if it boots. If it does, put the RAM back, then try again, if it does, put the hdd back and try again. It is a process of elimination. If everything is removed and it wont boot, it may be the motherboard. I have also seen bad batteries do this. There is a chip inside the battery that wont let the machine boot when the life of the battery is expired.
Aug 19, 2017 | Toshiba Computers & Internet
Advent laptop will not turn on
Test your battery on another similar laptop or use a known good working battery just to help rule the batter out. If it does not power ON using AC adapter, it could be something on the motherboard or your AC adapter. I suggest you first check the output of your AC adapter using a multimeter. The voltage reading you get should equal the one on the adapter's label.
Also check DC connection (where output jack of adapter plugs into the laptop) as sometimes it breaks and does not make contact with the motherboard.
And lastly may be you can try a power drain... remove the battery and unplug ac adapter. Press and hole power ON button for 30secs at least. Put back the battery and plug back AC. Power ON as normal.
Jul 28, 2011 | Computers & Internet
I forgot the bios password for my sahara 15wcs laptop. How can i remove it?
Hello !
On this tutorial we will remove the bios battery that remove the bios password , do follow this instruction
1-Turn off your computer
2-
Disconnect from Power, removing the battery.
3-Put his hands on a metal parts to separate you from the potential static electricity.
4- Close the computer and return on the back.
5- Loosen the screws that allow the opening of the rear cover.
6- Carefully remove the rear cover, without forcing.
7-You are at the inside of your PC, do not be fooled. Locate the BIOS battery which in most cases the shape of a large watch battery or camera: flat and round, but on a laptop is often enclosed in a small plastic cover and is connected to the map mother with two son. It will look like this (the color is subject to change): (look at the picture below )
8- Disconnect the power from the battery by gently pulling the plastic plug.
9- Press about twenty seconds on the power button on your notebook.
Reconnect the battery.
10-Close the unit by making sure to tighten gently, reconnect the po
wer supply.
Good luck & thank you for shoosing fixya .
Jul 11, 2011 | Computers & Internet
My T2300 wont boot up,I was trying to take a memory card out of the slot and the AC power outlet came out and the laptop came off. Now it wont boot up
Try removing the battery from the base. There is a sliding switch that will unlock it for easy removal.
make sure there is no power coming to the laptop.
Press and hold the power button for 5 seconds.*This should drain static from the motherboard
plug JUST the power cord back in.*To prevent any battery issues messing everything up
Press the power button.
If it boots you can put the battery back in.
* On my posts, i will try to explain what everything does for people who want to know
Oct 12, 2010 | MPC Computers TransPort T2300 Notebook
Battery Wont Charge on my Acer Aspire One Notebook Orange light flashes when power on button is pressed I have checked that the charger is working fine but notebook won't come on as battery is so flat. I...
Try this:
Drain the static on the computer by removing the battery and the power adapter. then press the power button for 1 minute and release. Then plugged the battery back in and turned on the computer, if the computer won't come on plugged the Adapter back to the computer and try turning it on.
If problem persist it is possible that the battery already busted and you need a replacement.
Hope it would help.
May 10, 2010 | Acer Aspire One PC Notebook
I left the battery in whilr replacing the screen
remove battery.
plug in the power supply cord.
restart computer.
shutdown computer.
replace battery.
restart computer.
Oct 25, 2009 | Advent Netbook
Advent 7094swf turned off and never turn on again
i would say the hard drive needs replacing
Oct 15, 2009 | Advent Netbook
I have a advent 7203 laptop - and doesn't want to power up. Ive removed the battery and pressed the power button and then tried it with just the power lead and then the battery but still nothing - any...
Jun 30, 2009 | Acer Aspire 5315 Notebook
Advent 9912 wont turn on
remove the ac adapter
take the battery out
be sure nothing is connected with your laptop
then press and hold the power button for 60 secs to drain static as it is the most probable reason laptops stops working.
then connect the ac adapter only and without the battery try powering on the system
if it powers on
you can again shut it down
insert the battery
it should surely power on
Apr 20, 2008 | Dell 2600 Notebook
Computers & Internet Logo
483 people viewed this question
Alun Cox
David Payne
David Payne
