Question about Toshiba Tecra A2 Notebook
Tecra a2 power light flashes orange, 4 short 1 long 3 short, pause then repeats.
Led light flashes 4 times, pauses then repeats
Which light blinks 4 times and pauses wash normal heavy etc if the model in the blue box is correct the to enter diagnostic press any 3 keys within 8 seconds I usually use normal and the 2 keys to the right all lights should light up if touch pad is up top where you had to open door to accomplish this then close the door after a pause the clean light will begin to flash example 7 flashes pause 1 flash these are your fault code it will do this 3 times for each code. The tech sheet should be behind the toe panel located below the dishwasher door which just repeats what I explained.
Feb 04, 2014 | KitchenAid KUDE70FXSS Builtin Dishwasher
Flashing directional lights on console....power loss
we need to know how the flashes repeat starting after the long pause how many flashes then a short pause how many flashes then a long pause and then the code will be repeated
Nov 05, 2011 | Amigo Rd 3 Wheel Scooter with 33AH Battery...
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
A beeping noise came on and the air bag light does not come on
If you are hearing a series of 5 beeps, 5 beeps and then a pause and it repeats, the airbag light is burnt out, and there is an error that the LFC ( light Flash Code ) needs to report.
Pull the cluster, and replace the airbag light, and then pay attention to the LFC that will be given ( example, 1 flash short pause, 8 flashes, slightly longer pause, then repeat the 1-8 pattern again, jsut as an example ).
Feb 05, 2011 | 2004 Ford F150
Won't Start Up
try this link it might help you get start again. laptop Won Start Up Google Search
Oct 19, 2017 | Toshiba Tecra TE-2100 Notebook
How to switch off engine service waring display
G'day mate i think you will find only the dealer can using a special little resistance tool which are normally to expensive for the average garage, take it for the service it new enough to look after
Apr 04, 2010 | 2009 Nissan Altima
Canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
Toshiba Tecra flash codes
Toshiba Tecra 8200
the power indicater light
Apr 02, 2008 | Computers & Internet
No startup
Majority of beep codes mean there's something wrong with the memory modules or a bad motherboard.
Try taking your RAM mods out and snapping them in. If you have 2, try using one at a time. Then you'll know which one is bad.
Here's a doc on how to do that:
http://www.crucial.com/install/sodimm.aspx
Nov 08, 2007 | Toshiba Tecra 8100 Notebook
Toshiba Tecra A2 Notebook Logo
406 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
