Question about Hayward SAND FILTER, PRO SERIES
Our sp0710 vari flo multiport value in the filter position is letting the water run out of the filter like it is in the backwash position
  • 93 Answers
SHUT OFF PUMP TAKE HANDEL AND MOVE TO DIFFERENT POSITIONS TO SEE IF THERE IS CHANGE THERE IS A WHEEL UMDER HANDLE THAT MAY BE OUT OF POSITION TRY A COUPLE OF ROTATIONS START PUMP AND THERE SHOULD BE A CHANGE NEVER TRY TO MOVE HANDLE WITH PUMP ON
Posted on Jun 30, 2009
How to backwash sand pro 550
turn filter off turn multiport to backwash turn pump on you should see water coming out of the waste line (make sure you have a hose on it with clamps) run for a coupleof minutes until water in sightglass goes from dirty to clear turn off pump turn multiport to rinse turn pump on run for 30 sec then turn off turn multiport to filter then turn back on thats all
Jul 17, 2014 | Hayward SAND FILTER, PRO SERIES
Tip
Backwashing A Sand Filter with A Push/Pull Slide Valve or Multiport Valve
Lots of people are first time pool owners and pool professionals forget to teach these "newbies" about the simplest aspects of pool ownership.
One of the biggest questions we receive from new homeowners is "How do I go about backwashing my sand filter exactly?"
It doesn't matter if you have a Hayward, Pentair, Jandy, Sta-Rite or any other number of Sand Filters on the market they all utilize the same basic valves for backwashing; a push/pull slide valve or a multiport valve.
To backwash with a multiport valve:
1) Shut off pump motor.
2) Press down on valve handle, rotate valve from FILTER to BACKWASH position.
3) Roll out any backwash hose or open any waste line valves.
4) Open air bleeder assembly on filter, and turn pump on.
5) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
6) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
7) Shut off pump motor and move multiport valve handle to RINSE position. Run on rinse for 15 - 25 seconds.
8) Shut off pump motor and move multiport valve handle to FILTER position.
9) Turn pump back on and note lower pressure.
10) Roll up backwash hose so the dogs use it as a chew toy.
To Backwash a sand filter with a slide valve:
1) Shut off pump motor, roll out backwash hose.
2) Twist to unlock plunger T-handle, push or pull(depending on manufaturer) the plunger 2" - 3".
3) Open air bleeder assembly on filter, and turn pump on.
4) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
5) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
6) Shut off pump motor and push T-handle back down into locked position.
7) Turn pump back on and note lower pressure.
8) Roll up backwash hose.
Now you are a backwash Guru!
More tips and tricks are available form The Ugly Pool Guy, www.WeFixUglyPools.com
on Dec 14, 2010 | Pool & Spa
How do you backwash your pool
if you have a sand filter or de filter turn system off then turn multiport to back wash turn back on let run until the backwash glass is clear turn off then turn to rinse turn back on for about 20 sec then turn off then turn multiport back to filter then turn back on
Oct 20, 2013 | Pentair 1.0 Hp Whisperflo Pump
Hayward vari flo valve
Does it filter? Does the pump have full prime? I'm not clear about how when the valve is put in the backwash position nothing happens.
Jun 15, 2013 | Pool & Spa
Hayward sand filter
Reference your pressure gauge as the 12:00 position. Going clockwise-
12:00 is Filter, normal running position
2:00 is Waste, water goes from pool and exits the waste line, bypassing filter.
4:00 is Closed, used only when servicing equipment
6:00 is Backwash, reverses water through the filter and goes out the waste line.
8:00 is Recirculate, water bypasses filter and returns to pool.
10:00 is Rinse, water goes through filter and exits to waste line, used briefly after backwashing to clear sediment from filter.
Note that the "pointer," not the handle that you grab, indicates which setting you are on.
May 19, 2013 | Pool & Spa
How to know what cycle to use or when to use filter, backwash or rinse?
during normal operation, your multiport valve should be in the "FILTER" position.
Once the pressure in the filter reaches 10psi more than what it was when the filter was clean, you should backwash. turn the pump off, press down and turn the multiport valve to backwash. turn the pump on and watch the effluent water until it goes from dirty to clean. Then place the multiport valve to the rinse position, this will rinse any remaining dirt from the top of the filter and valves so that it does not return to the pool. Once the water comes out clean, return the valve to the filter position.
Do not turn the valve while the pump is on, always make sure to turn the pump off before servicing any equipment.
Aug 01, 2011 | Intex 2100 Gph 95 Hp Sand Filter Pump With...
Wicor high rate sand filter P20. When I have it on "filter" there seems to be some water starting to leak from "backwash" hose.I only let it run maybe 30 seconds. Not looking for it to blow out any seals...
If it has a multiport valve, most likely the spider gasket inside has damage or has come out of place. A broken stem spring can also cause water to bypass out the backwash due to not having enough force to seat the seal. Take the multiport apart and check the spider gasket and spring.
Aug 15, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward filter problem
YOUR HANDLE IS NOT SEATING IN THE RIGHT POSITION THERE IS A SPROCKET UNDER HANDLE THAT MAY BE DAMAGED TRYSETTING HANDLE TO DIFFERENT POSITIONS SEVERAL TIMES IT MAY HAVE DEBRIS UNDER IT MAKE SURE PUMP IS OFF.TAKE HANDLE ASSEMBLY OFF AND CHECK SPOCKET
Aug 04, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
176 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
