Question about Toshiba Satellite Pro A200-EZ2204X Notebook
The drive is not being recognised by the laptop - the yellow light on the outside casing of the drvie is constantly on, the eject button will not work and can only be opened by inserting a paperclip in the release hole. If a CD is inserted it is not recognised When starting up the computer takes a couple of minutes to automatically open up XP - but when the DVD drive is removed it goes straight into XP
    President:
  • Toshiba Master
  • 1,314 Answers
The drive is bad and needs to be replaced. The latency you experience in loading XP when the drive is connected is because the computer is attempting to recognize the drive and it cannot.
Posted on Jun 30, 2009
How bad is it to drvie with check engine light on
It depends on what set the light. If its caused by a transmission problem then the car will go into what is called a limp mode. It is designed that way to allow you to get it into a service dept. without having to be towed. If it is an engine problem causing the light, the car could run rich (using to much gas) and cause horrible gas mileage and will eventually cause further problems if you continually drive it. In ether case when it is a yellow light it is only a caution and needs to be looked at. Take the car to Auto Zone and they will check the light for free. BUT!!! if it is a red light shut it down!
Apr 12, 2013 | 2009 Chevrolet Traverse
DVD drive on Asus a9rp not being recognised. Selected in the bios set up. Just stopped working. Yellow activity light comes on for a while when a disk is inserted but disk not recognised on the screen
Your CD drive unable to read the CD inserted in the drive.So please checkout the lense or check the data cable which connected to cd drive is working properly or any fault is there.
Aug 19, 2010 | ASUS A9RP Notebook
When i connect my wd 1tb hard drive i get usb device not recognised plz help
Hi sexybarneygu, Assuming you have tried other USB ports getting the same problem, I recommend you return it (if it's under warranty) if not, remove the Hard Drvie from the casing and connect it to another computer internally (I dont want you to get another external case for you Hard drive because you hard drive MIGHT be the one with the problem and you cant fix it (you can't fix hard drives, just work around it in order to get your data back and then trow it away). If the other computer sees your hard drive ok, then go buy an external case and install your hard drive there. make sure it's the same interface - most likely SATA interface. I'm 80% sure it's just the casing not the hard drive. Don't forget to rate if my answer helped you. Thank you :D
Apr 28, 2010 | Western Digital My Book Essential 1TB...
Won't boot, dvd drive only shows yellow light on
After a Format EVERYTHING is GONE... It is a blank thing. It only know to boot from an install disc. So you must now put a Windows DVD or some sort of Boot setup Disc in, and if the Windows disc, you should perform a re-install of the Operating System. As until that is done you cannot use the PC, as a PC. try that and get back to me.
Feb 18, 2010 | HP Pavilion dv9000z Notebook
Maxtor one touch iii unable to read drive; the external hard drive previously worked and now it doesn't read the drive
please remove the raw drive from the casing
it may be a sata drive of maxtor please power it up directly to your pc with a sata power and sata cable
the drive will get recognised .
if it gets recognised it means the interphase between the disk and the ext casing has been damaged
if you fail , the disk has lost its firm ware or rom chip rom bin file.
both can be flashed and recover the drive
BEcaerful you can break the plastic casing while removing the raw drive as it had been machine dyed and fixed and you may not find any screw s outside
datarecoveryfactory
Sep 04, 2009 | Maxtor OneTouch III FireWire 400 (F01G500)...
Black screen
check the cpu, and connection of it compunents..
Jun 19, 2009 | Dell Latitude D600 Notebook
Lacie 500Gb Hard Drive Porsche design
Hallo,
my disk, when on, is not recognised by Windows while the light is flashing between yellow and orange fast (like a car's flash -faster-). please could anyone help me? - i need my data!
Thank you.
Aug 21, 2008 | LaCie 500GB FireWire-400 Porsche - 7.2K...
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
70 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
