Question about Weber Genesis Silver B Grill
How do I replace ignitor wiring - or whole set? My dog chewed the wire ... need to disconnect both ends - part leading to grill looks very rusted ... suggestions? Part type/name/number? Help!
  • ked208 Jul 01, 2009
    I had asked for advice on the ignitor wiring for a gas grill - not an oven. Still need help...
    President:
  • 942 Answers
Try to click this site below
http://outdoor-living.hardwarestore.com/58-233-grill-repair-parts.aspx
Good luck!!
Regards
PCmania
Posted on Jul 01, 2009
  • Neciforo Llanto Jul 04, 2009
    just replace the whole set of your ignitor wiring
    Good luck !!!
    PCmania
    Brigadier General:
  • 3,917 Answers
This advice is for GAS ovens with glow bar type igniters. This is a fairly simple repair that MOST do-it-yourselfers can accomplish with just a little guidance. But, first, here’s a little gas oven theory to help you better understand how to determine if an igniter is bad:
The way the ignition system in most of today’s ovens work is like this:
  1. Set the oven or broiler temperature.
  2. The igniter begins to glow.
  3. Once the igniter reaches a certain current potential, the gas safety valve opens.
  4. Gas is introduced into the manifold and you have ignition.
  5. NOTE: It can take roughly 30 – 90 seconds from the time you set your oven temp to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the oven to prevent free flowing gas from accumulating in your home without ignition. That’s why you typically don’t hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
An easy way to determine if you may have an igniter problem is to check BOTH your oven features. If the oven doesn’t light, check the broiler and vice versa. Since both the BROIL manifold and BAKE manifold are fed from the same gas source, but have separate igniters, it’s an easy assumption to make that the igniter may be bad, if one or the other doesn’t light.
The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn’t produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won’t light). Longer ignition times can be another symptom of an igniter possibly going bad.
For this solution, however, we’re going to assume you have a bad igniter and need to replace it. Follows these steps:
NOTE: The same method applies to both the broiler and bake manifold.
  1. UNPLUG the range and turn the gas off if you have a local gas cut-out valve (it is recommended that you do).
  2. Open oven door and remove (if possible). Refer to your owner’s manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn’t shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
  3. Remove the oven racks, and remove the oven pan. (There are usually two screws either in the back or front of the oven holding the pan in place).
  4. Remove the Flame Spreader. This is a metal plate on top of the manifold.
  5. The igniter will be mounted directly to the gas manifold. Follow the wires that lead to igniter. It will either be plugged into a connector, or be connected together with ceramic wire lugs. Your replacement igniter should come with extra ceramic wire lugs. In the event the plug does not match the one on your range, cut the wires and connect using the ceramic wire lugs. DO NOT use standard wire lugs, they are not heat resistant and will melt.
  6. Unplug the old igniter and remove the mounting screw holding it to the gas manifold.
  7. Install new igniter on gas manifold using care not to handle the element on the igniter with your hands. The oil from your hands can cause damage and/or premature failure. The igniter is also considered FRAGILE.
  8. Reconnect the wires using the recommendations mentioned in Step 5.
  9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 – 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
  10. Reinstall the flame spreader, oven pan, and racks. Reinstall door if necessary.
Most igniters cost around $50. Prices will vary with models. I hope this information is helpful.
Thanks for contacting Fixya
Posted on Jun 30, 2009
How do I replace ignitor switch in thermos gas grill, if this is what is what I saw?
If that white is ceramic, I think it is the actual ignitor, not the switch.
Apr 29, 2017 | Thermos Stainless Steel Gas Grill
I replaced an ignition switch on my grill and again it is not functioning. It has new batteries but no clicking or igniting any of the spark ignitors. Is it still an ignition switch problem or could...
First off, is the battery installed in the proper position. The positive (+) end should be facing out. I that's not the problem, check the ground wire to make sure it is connected solidly and no rust in underneath it. Then check all the wires to each ignitor , making sure they are not damaged.
Jul 13, 2011 | Brinkmann Charmglow Stainless Steel LP...
Ignitor wire disconnected from the bottom of the grill. wondering where you connect the clip to? not seeing anywhere after inspecting it.
Kurt, you may have to remove the ignitor button to see the male lug that the wire's female end slides onto. It will either be a copper or stainless steel lug.
Hope this helped you.
Jun 26, 2011 | Char-Broil Quickset Traditional 463761006...
I have been using the grill for about a year now. All of a sudden the electronic igniter dosen't spark on all control knobs. I checked the battery and replaced it with a new one. It did not change...
First, Bud make sure the battery was installed facing the proper direction. The Positive end (+) should be facing out when installed. If that's not the problem, check the wiring from the ignition module to the each burner ignitor. One may be loose or the grounding wire from the ignitor module to the grill's frame, may have lost contact. Also, look carefully at each ignitor tip at the burners. They may have an accumulation of grease, which needs to cleaned off.
If all that doesn't resolve the problem, you will need to replace the ignitor module. You can purchase one online directly from NEX Grill http://www.nexgrill.net/ or from Factory Appliance Parts
http://www.appliancefactoryparts.com/search/index.php
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 04, 2011 | Nexgrill 720-0234 (LP)
How do i remove the ignitors out of a charmglow grill model number 720 0036 HD 05?
The ignitor electrode(s) are held in place my a small tab that's attached next to each main burner with a small screw. To totally remove the ignitor electrode, disconnect the wire to it first, by pulling the wire's sleeve off the ignitor pin. Then unscrew the holder/tab. There should be no need to replace the wires, if you are just replacing the ignitor electrodes. Be sure to remove the battery from the Ignitor Module, before trying to remove the electrodes.
Apr 10, 2011 | Brinkmann Charmglow Stainless Steel LP...
My main ignitor works and the side burner ignitor doesnt...it not 1 year old yet
Check the ignitor wiring going to the side burner to make sure that both leads are stil connected (ie making contact). If it appears that they are, remove the end of the wire on the side burner igniter and push it back on again. It may have just lost the ground to it.
Jan 30, 2011 | Fiesta Blue Ember Gas Grill
Ignitor Quit Working
Remove the switch and the wire from it as you will have this little switch and a wire push the switch and watch the end of the wire there should be a spark it not you can dog wife check it if you want too. stick the end of the wire to the dog re the wife and push botton if they scream and jump a few feet the switch is good . jus kidding . if it is good just locate the end of the wire so that it is in a more effective position to light the gas,
Aug 08, 2009 | Grilling
My dog chewed up wiring on outside unit and i dont know where they hook up it is a 4 wire set up with red white blue and green large ac unit dog chewed thru little brown wire leading to house and now ac...
That wire is to your thermostat which of course turns the A/C on/off. One thing you can do is to splice the wire back together w/ small wire nuts (available at hardware store or wal-mart, and just hook it up color to color and then tape w/ electrical tape. Make sure you turn your breaker off and turn off the thermostat control.
Feb 11, 2009 | Heating & Cooling
Headphones
Hi Meanmama
Is there still enough cable left from the headphones to the chewed end for comfortable use? If not you might have to replace the whole cable length.
If not, you can just fit a stereo mini jack (3.5 mm diameter) on the chewed end.
For this you will need a soldering iron and some basic soldering skills.
Are you able to solder a plug onto a lead?
Sep 25, 2007 | Logitech FreePulse Wireless Consumer...
Weber Genesis Silver B Grill Logo
126 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
