SOURCE: a/v settings
my husband and I were having the same problem with the universal remote, If you buy a universal remote make sure it has a input button and make sure you try all the buttons after you put in the code. For my universal I had to codes that worked but only one that let me fully use the controller. On the remote you should have a input button that is the button to change your tv to be able to us the av channels. Hope this helps
SOURCE: Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
SOURCE: can get tv to change to av1
The Input button on the original remote is needed to switch to the AV1 or AV2 connections. Unfortunately, I do not believe that the Sanyo DS27930 has an equivalent Input button on the TV. A replacement remote is available here: http://www.emtcompany.com/sanyo-ds27930-remote/rc64.html . Other universal remotes may be able to transmit the Input signal. You will need a remote that was programmed over 6 months after the TV was released with an Input or Source button. Then try all Sanyo codes until you find one that controls all of the features.
I hope this helps.
