Question about Canon NP 6050 Copier
Changing the drum on a Canon NP-4050?
Basically where do you start when taking the old one out? And what do you watch out for? I can buy a new drum myself for $230 and the tech will charge me around $500. Naturally, I'd like to do this myself since we own the copier.
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,346 Answers
Re: Changing the drum on a Canon NP-4050?
1- open front door
2-on the right side put lever down ( disengages developer to drum)
3- swing toner holder ( dispenser ) to the right
4- bring green lever down ( has two belts )
5-unscrew the gray screw and pull out the unit ( this is the drum UNIT)
6- replace and do all the steps backwards EXECPT
7- put a pencil or paper in a slot on the right to cheat the contact and turn on the machine
8-on the left side under the counter there is a small hole insert a paper clip to engage service mode
9-there are two numbers on the new drum.
10- go to primary and set the drum primary then go to the next number and insert that.
11- go to apvc and select that
it should rotate and stop ttake out cheater and make a copy
good luck
Posted on Nov 08, 2007
0 characters
3 Points
NP 4050 -
The door may be closed, but there is a inter lock switch that is not being closed. If you have all four paper tray, try to turn the copier off and disconnect the bottom two cassette's from the back of the copier and turn it back "ON" and see if the copier works. If it dose you have a problem with the bottom two tray's. You have a very old copier, can you do with out them? If not the switches are toward the front & it may just be knocked out of place... Good Luck...
Sep 17, 2009 | Canon NP 6050 Copier
Yield for Drum rated @ 120,000 copies. If you are asking for depends on who you call for parts / service. Hope this helps
Aug 08, 2009 | Canon Printers & Copiers
Can u tell me the load capacity of canon 4050
2.5 kva with 4 battrys any company
best for u.
Aug 04, 2009 | Canon NP 6050 Copier
Canon 4050 copier has line down the paper. How do I get rid of it
take out toner and shake it to clean the toner cartridge
or you need a new drum
Apr 16, 2009 | Canon NP 6050 Copier
I want to bye the model np 4050 i want known the price
I happen to have a NP 4050 for sale. Please contact me at Thanks.
Feb 19, 2009 | Canon NP 6050 Copier
Service manual
you can go up on the web. look up INTRAVIA COPIER MANUALS, THEY HAVE MANUALS FOR ABOUT EVERY COPIER dont know the cost they are in buffalo new york, good luck
Jan 29, 2009 | Canon NP 6050 Copier
Canon NP 4050
I use this one
Oct 19, 2008 | Canon NP 6050 Copier
Cannon np 4050
The toner is not adding correctly into the developing assembly. 1) If toner hopper is overfilled, the toner motor worm gear splits as a result of the hopper becoming packed tight. 2) Sometimes the worm gear splits under normal use.
Jun 03, 2008 | Canon NP 6050 Copier
Canon NP-4050 printing almost completely black pages
This problem appears to be that the scanlamp cable has fatigued and become open-circuit. This can be checked by selecting A3 and pressing the START button while having the lid up. Watch to see if the light stays on all the way through the forward pass of scan cycle, it can be intermittent. Make sure that the machine is unplugged before attempting to replace the cable.The drum is definitely on its way out at that amount of copies, but can be made to last a fair bit longer with some fine-tuning.
Nov 08, 2007 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
115 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
