Question about Epson Stylus Pro 10000 InkJet Printer
Reload Paper constantly shows up
The message "Reload Paper" keeps showing up even after paper has been loaded, reloaded and even after a new roll of paper has been put on the spool.
  • 21 Answers
This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
Posted on Mar 12, 2010
You have to enter Printer Settings menu, and switch OFF Paper Align. Check.
Posted on Nov 06, 2009
Error, paper out, when paper is loaded.
check there is the sensor cable is broken or the sensor is faulty.
Oct 12, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
Flashing paper and power buttons
This error means jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following:
Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
Manual Feed Slot: See page 15 of your manual for loading instructions.
Roll Paper: Cut off the printed portion with scissors, then remove and reload the roll paper
Mar 08, 2014 | Unknown Epson Stylus Photo R2000 Ink Jet...
Loading roll paper for an Epson 7600
Remove paper, blow on the little window to the left of the bottom-right screw inside front cover...there's a sensor in there. I read this somewhere else, and it fixed my loading problems. Good luck!
Jan 08, 2013 | Epson Stylus Pro 7600 InkJet Printer
How do I clear a paper Jam
Try either of the following methods to clear the paper jam. The operator panel displays the Ready message when the jam is cleared.Method A:
  1. Press Paper Rewind until the Paper Empty message appears.
  2. Press Paper Advance to re-load the paper into the printer.
    The printer advances the paper, then cuts and discharges about 24 in. (61 cm) of blank paper. This reduces the possibility of fingerprints or other damage to the prints.
Method B:
  1. Turn off the printer and open the upper cover.
  2. Remove the ribbon from the printer.
    Caution: Prevent damage to the printer. Do not pull abruptly on the paper.
  3. Slowly and carefully pull the jammed paper out of the printer.
  4. Cut off any damaged or printed areas of the paper. Do not damage or mark any of the rollers.
  5. Close the upper cover and turn on the printer.
  6. Press Paper Rewind to rewind the paper into the printer.
    Note: If the Paper Jam message still appears on the operator panel, press Paper Rewind again.
  7. Open the upper cover and reload the ribbon.
  8. Close the cover.
  9. Reload the paper.
Note: If the Paper Jam message still displays on the operator panel, and you are at the end of a paper roll, it is possible that a segment of paper is too short to automatically exit the printer. Remove the front cleaning roller and remove the segment of paper.
Jan 03, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
"reload paper" message
Lower paper sensor was completely dusty. Just blowed it and it works.
Apr 15, 2009 | Epson Stylus Pro 7600 InkJet Printer
Message keeps saying out of paper and paper tray is full.
ok heres what u can do go to ur printer options and check if the paper is set to "letter" or "a4"
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
Message shows paper jam even though there is no jam
take all the paper out make sure there is no dirt or dust in the corners,then unplugg the machine for 30 sec. power back up and reload the paper
Feb 26, 2009 | Office Equipment & Supplies
9600 keeps telling me to RELOAD paper
just flick the paper lever up and down. dont fiddle
Jan 16, 2009 | Epson Stylus Pro 9600 InkJet Printer
Out of media Design Jet 750c plus
u could try reloading the paper roll, i have had that prob, and had to reload paper. it always fixede it for me. good luck
Oct 14, 2008 | HP DesignJet 750c plus InkJet Printer
Epson Stylus Pro 10000 InkJet Printer Logo
707 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
